Crewcab Only Thread.
#3272
#3274
Heads up west coast CC folks. https://bend.craigslist.org/cto/5878997656.html
Not a bad truck honestly. I like em a little rough around the edges.
#3275
#3277
Slow Build
I have been trying to post this in this forum. I think I have it figured out.
https://www.ford-trucks.com/forums/1...cab-build.html
#3278
78 crewcab cummins swap
hi all here is my 78 first pic is one the PO sent me and second is when it showed up in the yard, it will be put on a 93 f350 4x4 crewcab 8 foot bed frame and be cummins converted
Last edited by Earnie Rosenow; 11-20-2016 at 08:03 PM. Reason: forgot to add that it will be a 4x4
#3279
I have to replace the front tank on my 79 f350 2wd crew cab longbed. Will any of these tanks work? I am hanging a dana 60 under the front, I'm not sure if that changes anything about the tank. Also, my truck has the EEC stuff in the tank. Do I need to replace it? It was all junk, and it will be more stuff to purchase
#3280
I have 1974 crew cab without a fuel tank. does anyone know if these tanks from LMC are the correct ones for this truck?
Truck Parts and Truck Accessories
#3282
Headliner project 78. Crew
I have a 78 crew cab in need of further refinement. Thought I would tackle the missing headliner. I have a oem standard cab headliner for templating that front and rear halves of the new one. I also have the 4 trim pieces for the standard cab. My crew still has the plastic center strip. Some questions to any that have been here before.
1) what does the center chrome trim piece look like that goes above the doors? I thought I could get more standard cab pieces and cut the corners off and splice something in?
2) what did you use for the headliner? I was considering some thin pegboard material without the holes.
3) what did you cover it with?
4) did any of you add speakers or anything else? I like the center overhead console in our suburban. It has place for garage door opener, sunglasses and courtesy lights. Maybe where the rear heater controls are some gauges could be swapped in.
Any thoughts or pics? Let em rip
#3283
I have only seen a white plastic piece used to cover the middle seam on a CC. I would think that the rear pieces that ge along the rear doors and along the back looks like the front door one?
Material to use and or to cover it with. Ideas below.
https://www.ford-trucks.com/forums/1...eadliner+cheap
http://www.hotrodders.com/forum/what...yl-228613.html
#3284
another option, worked well took a heat gun to the corners and formed right in....
Also... my old dodge ram charger and a very similar middle strip in it, 99 percent sure it would work and there still in every junkyard out there may try that... blazers may also have something similar but not sure....
