Roof/windshield seam, drip rail replacement- I just finished replacing a roof that was lowered by mother nature (tree fell on my crew) back to factory specs. I took the time to find the seams, seperate there, rust treat, weld together at the seams, square the windshiled (I cut the A pillars in half since the upper windshield seams was squished, and one pillar got bent in the impact), flush the rear window, fit the drip rails, etc. It sounds like alot, but if you can weld fairly well, it's not too bad. I have some shots of it on car domain and old ford crew cabs (not to endorse or advertise) if you want to look at a quick overview of replacement. Oh Yeah, you gotta find a good crew roof, or weld two together to get the right length...no skins available that I have ever heard of, or even heard mention of!!
Happy Motoring-Zeek
Any and all info on crew cabs help I DO want to know about what yours has it helps me a lot keep it all up and keep the info coming to keep our crew cabs trucking
Hi, I am new to this site. I just purchased and brought home a 1978 F-250. It has aluminum slots on it for rims Is this factory? It also has factory Air. 400ci engine and automatic. It is pretty rusty. Are cab corners the same for a crew like mine if I ordered corners for a reg cab? I hope to get some pics of it posted soon. Thanks for any help. oh yeah it is a crew short box.
Hello -- I'm new to this thread and a proud owner of a 1975 F-350 2wd lb crew. Rusty front floors,but all the hand made parts (rear floors, entry wells, doors and the like) are all good. Here's the question -- What can we use as headliners? Earlier posts mentioned the edge trim and crosspiece and they're all there. Various companies offer replacement liners for standard cabs. Can tw oof these be made to work? Thanks for any help...
well got truck home on sun . i have to replace front floors and repair rust around windshield and drip rails, so now the fun begins !!!
budget for build up is 12000 gameplan is:
1 i also got a 78 cc ranger xlt that is pretty much rust free little rust around drip rails should i swap cabs and fix a couple dent in 78 cab
2 suspension i would like to lower this 2 inches do they make lowered i beams for f350? every thing will be replaced with new tie rods bushings springs ect pump and box also
3 brakes are there better rotors calipers and pads for 1 tons this willl get hydroboost and possibly disc in rear if someone makes a kit for a dana70
4 wiring harness whats the best one for these trucks must be set up 4 power windows as this will be done also
The overall plan for the truck is to have the look to the 76 and the comfort and reliability of the Superduty. It is going to be a personal and possible work truck so I want some comfort for the family and I on long trips and the capability of pulling my 30 foot gooseneck a lot of the time. I plan on using a much of the Superduty as possible. Of course the plan may change a little along the way, but I have pictured this project in my mind for a long time so I hope it doesn't have to change much and disappoint me.
I'll try to paint the picture for you as best as I can. The chassis is going to consist of a 01' F550 7.3 Powerstoke 4x4 auto w/Gear Vendor overdrive. Front and rear will have 4:88 gears and 19.5 x 6.75 factor Alcoa rims. I was going to fab some front and rear bumpers but now with the body set I think that I can use a stock front and a nice drop bumper I already have. The body is going to a 76 Crewcab longbox with custom made dually flares. I had a few Mustangs on the past and liked the boss stripes and shaker scoops, so that's the look that I'm going after with the paint scheme and the functional shaker hood scoop. Another mod I have planned for the exterior is to incorporate 08' mirrors to get some better visibility for hauling and a 3rd brake light for added safety. Also for safety it will have the factory ABS, Airbags and e-brake. The interior will consist of the Superduty dash, steering column, seats, carpet, head liner, overhead console and lighting. As for right now I know that I'm going to make custom pillar pod for gauges and custom door panels( I know stock panel aren't going to last with 3 kids in and out of the back) I'm thinking some form of fiberglass.
I guess the rest of the plan I'll make up as I go.
sounds like a cool build - and like the last guy said - I wanna see pics and the link doesn't work.
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1989 Ford Ranger = never gonna be done...
1974 Ford F250 4x4 Crew cab Build thread in "motor swap" forum
1972 Alfa Romeo GTV
1991 Dodge 250 cummins - motor donor
1999 Toyota Tacoma 4wd = DD/weekend toy
