Crewcab Only Thread.
Old 01-12-2016, 03:07 PM
dfosucks's Avatar
dfosucks
dfosucks is offline
'77 crewcab front end pinion angle
Hey just joined up. Bought my 77 c.c a few months back and it has about a 4'' lift and the pinion angle is really steep. I have had a few shops look at it and they've said it cant be changed because it would put the castor angle out and it wont steer right. any ideas how to fix this? I dont intend on doing a lot off off roading but would like it to work in the snow safely.
  #3062
Old 01-12-2016, 03:10 PM
jgoodman6891's Avatar
jgoodman6891
jgoodman6891 is offline
Ran across this today. Now I got to figure out what to trade for it.
  #3063
Old 01-12-2016, 04:16 PM
Djstright's Avatar
Djstright
Djstright is offline
If you're worried about safety then leave it alone. Changing the castor angle with make it unsafe having an odd pinion angle will only make it vibrate which you can fix with a different driveshaft. But if the castor is good then your pinion angle should be fine it must just look funny.
  #3064
Old 01-12-2016, 07:37 PM
jtjohn302's Avatar
jtjohn302
jtjohn302 is offline
anybody on here own this truck? i want to get mine sitting like this!
  #3065
Old 01-14-2016, 08:51 AM
Wyofordguy's Avatar
Wyofordguy
Wyofordguy is offline
Has anyone had any luck finding rear door window regulators. I thought I could modify one from a front door, but it looks to be a real pain to get it apart and still be able to reassemble it into something functional. Hopefully I'm wrong?
  #3066
Old 01-14-2016, 05:38 PM
dfosucks's Avatar
dfosucks
dfosucks is offline
OK> I haven't run the four wheel drive yet. Maybe it will be ok. What did you mean by a new driveshaft
  #3067
Old 01-14-2016, 06:22 PM
Djstright's Avatar
Djstright
If your pinion angle is off you can stop the vibrations with a double cardian driveshaft. It has two u-joints on one end to cancel out the vibrations.
  #3068
Old 01-14-2016, 06:26 PM
dfosucks's Avatar
dfosucks
dfosucks is offline
It has a cardan joint already coming off the transfer case. Do you think it might operate ok as is?
  #3069
Old 01-14-2016, 09:24 PM
Djstright's Avatar
Djstright
Only one way to find out
  #3070
Old 01-15-2016, 01:33 PM
Awitte58's Avatar
Awitte58
Awitte58 is offline
Just gimme an address and ill come get it!
  #3071
Old 01-16-2016, 06:14 PM
78Extended's Avatar
78Extended
78Extended is offline
thinking about selling my 73 crew cab long bed project. as I have been into muscle cars for the last few years and the trucks been sitting in the garage and I don't see me getting to it any time soon, so I might as well let someone else enjoy it. it has 10 inches of lift 38.5" swamper boggers brand new, dana 60's with 5:13's Detroit locker in the front, spool in the rear, rear disc conversion, cross over steering set up, transfer case parking break conversion, currently 360 np 435 205 case have extras that could go with, 429 c6 extra 205, body needs cab mounts and floor pans but have them and can go with, 4 extra rear crew cab doors, double double monster roll bar, captains buckets from 79 bronco, and lots more. currently runs and drives but needs to be finished. truck located in southeastern pa. price will vary depending on what parts go with the truck but somewhere in the $6000 -$8000 range. where would be the best place to post this for sale as I have been out of the truck world for a few years. thanks Brandon 215-353-2053.
  #3072
Old 01-16-2016, 09:12 PM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
Best place to sell it is either Ebay or craigslist. Sounds like a good truck. Any pics? Hope you sell it.
  #3073
Old 01-18-2016, 04:00 PM
highntight's Avatar
highntight
highntight is offline
X2 on the pictures, Sounds like a beast.
  #3074
Old 01-21-2016, 06:34 AM
PACrewCab's Avatar
PACrewCab
PACrewCab is offline
Wyofordguy, there are a few rear door regulators on ebay right now but they are pricey. I have extra door parts but I'm not sure if I have any extra regulators. I know I just used a pair to piece together a set of doors so I can sell them. I'll look around to see what I have.
  #3075
Old 01-21-2016, 06:38 AM
PACrewCab's Avatar
PACrewCab
Rbeck,
Nice old truck. I like the old Ford logo on your seats. Very cool!
Quick Reply: Crewcab Only Thread.
