__________________
76SCS
Wanted:73-75 F350 SCS 390 SoCal ONLY--Fathers Formally Owned:67 250,69 250,77 350,93 E350
I'm the words Youngest FTE member DOB:8-16-94--Join The Socal Chapter *Here*
I know almost everything I just cant remember it all at once. FTE-is-#1
Hey guys, since this is a crewcab specific question, i'll post here rather than suspension forum.
I put a 4" suspension lift kit on my 1978 F250 4x4 crewcab. The rear driveshaft is a two piece shaft that has a carrier bearing between the longer section of shaft (front section) and the shorter section (rear section). Right now the whole body is off the truck but all the driveline is installed (engine, tranny, etc). My concern is the angle of the two drive shafts by the carrier bearing. Does anybody here have a lift kit on their crew? Did you have to relocate the carrier bearing lower to minimize the angle on the u-joint by the carrier bearing? If you didn't, do you have any drivetrain vibration at highway speeds?
Thanks,
Eric
__________________
1996 F150 4x4, 351, auto, LB, K&N Filtercharger, "Silver Bullet"
1978 F250 CC, sb, 4x4 "in the works"
roxndirt64, thanks for the reply. How thick is your spacer, ie. how many inches down does it drop the carrier bearing? How is the spacer made? tube steel, C channel, etc?? if ya could shoot a pic, that would be super! Thanks, Eric
__________________
it all depends on how much lift, as to how much of a spacer for your carrier bearing to line up. I can take a pic tomorrow. Maybe you could tell me where to go on here to post the pic. Im not real computer savy. lol Otherwise Ill need an email.
__________________
64' 4x4 390, ps, disc brakes, 1 ton axles,
75' cc 4x4 460 39.5 Iroks
Rox - yea it's a 4" lift, but I also just thought about the fact that you probably have a divorced transfer case since yours is a '75. Mine is a 78 with the married NP205. There maybe some angle differences between the two. I guess I might have to just measure mine to be exact. I would however like to see how to make the drop bracket. you can email some pics to emjohan@mchsi.com that show the dropped bracket.
Thanks!!!
__________________
no probably not if i found a good one i wood keep the hole thing, but i was hopeing someone sold replacement pannels. i just havent found replacemnt roofs to bad . ya its that darn probablem the foof line rusted right off and the hole truck is alright shape other then that. So if you now of any one that sells new roofs for crew cabs please let me know. Thanks
