Crewcab Only Thread.
#2702
#2703
#2705
The ZF5 has a better gear spread, no goofy adapter, it uses all Ford parts and I found a 2wd ZF5 with a large tailshaft mounted E-brake for a good deal.
I routinely pull and sell full ZF swaps.
I know a guy that I can get Gearvendors from for $900 used and may get one in the future to put behind the ZF5 but that's a lot of money for a small luxury.
If you want to go with an automatic then depending what motor you have there are multiple choices.
#2706
Did you notice an improvement in fuel economy with the OD?
#2707
#2708
#2709
#2710
#2711
#2712
460 with a Jacobs Pro-Street box, Jacobs Ultra Coil, plugs gapped at 0.090, Edelbrock 600cfm with about 20 hours of tuning, ported edelbrock intake, and a duel catalyst device, 14" K&N air cleaner, ZF5, 3.73 axle ratio, 315-75-16 Kuhmo Road Venture tires. That tank was 100% freeway using a very light right foot letting it float between 55-60.
I have been taking it as a personal challenge to get 20 mpg out of a 460, even if only for a single tank.
My future efforts are to build more low end torque into the motor with D0VE heads, cam, higher compression, add the Tri-Y headers I have waiting for it and go to 3.54 axle ratio.
#2713
I did a post in the regular 73-79 forum about fitting 1995 crewcab power windows and locks in a 75 crewcab, I posted it there as most dent side owners are not crewcab owners and could use the info, so then I thought I would do a reply here for any CC owners who may be interested in the upgrade, it's not super hard, it's cheap and it works great.
you have a link?
#2714
https://www.ford-trucks.com/forums/1...+locks+crewcab
Do you see the blue line with User CP, Albums, FAQ? See the search on that line?
It has a drop down search menu arrow, go to the "Advanced Search" option, type in there say "blab la bla" and then go to the lower right column and high light 73-79 -forum. Select it and then you will have a detailed search just in the 73-79 forums.
You are welcome.
I typed this in the Advanced Search window. (73-79 forum about fitting 1995 crewcab power windows and locks in a 75 crewcab) gave me 2 threads in 5 sec. The one link I posted above was the second one. BAM
You are welcome.
#2715
Ryan
