Crewcab Only Thread. - Page 177 - Ford Truck Enthusiasts Forums
  #2641
Old 07-20-2014, 05:06 PM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
Randy, I'm back, and I measured my frame for you. I got 5.5" for the DS frame perch and 4.5" for the PS. That is from the crossmember perpendicular up to where the rubber mount goes. The numbers are approximate.
  #2642
Old 07-20-2014, 06:06 PM
Randy Obrien Randy Obrien is offline
Randy Obrien is starting off with a positive reputation.
hey thanks. i definitely have the wrong perches then, or at least 1 wrong one but probably the pair. my dr side is 6.5 inches and my pas side is 4.5 measuring as close to 90 degrees from the crossmember as i can.
  #2643
Old 07-21-2014, 02:00 AM
73cutsom's Avatar
73cutsom 73cutsom is offline
73cutsom is starting off with a positive reputation.
I purchased a 73 crew cab recently and found out the roof needs to be replaced, just wondering if any one that's done the van roof, has pictures or know of a build thread.thanks
  #2644
Old 07-22-2014, 11:29 AM
79Supercab's Avatar
79Supercab 79Supercab is offline
79Supercab is starting off with a positive reputation.
So I was perusing my old posts, looking for a '78 I had at the time, and I found this post:
http://www.ford-trucks.com/forums/23...ml#post1746875
I posted that on 7/4/2004.....only took me about 10 years to get what I wanted . The options powertrain options I want now are a little different than back then, but the base is close.
  #2645
Old 07-22-2014, 12:45 PM
somethingclever's Avatar
somethingclever somethingclever is online now
somethingclever has a great reputation on FTE.somethingclever has a great reputation on FTE.somethingclever has a great reputation on FTE.somethingclever has a great reputation on FTE.somethingclever has a great reputation on FTE.
your truck was on c-list about 3-4 months before you bought it for 9k.....i really should've made it happen and flown out to check it out.
Glad you are happy with it...hopefully the things done by the guy you bought it from were done correctly.
  #2646
Old 07-28-2014, 12:31 PM
Can anyone point me as to how the factory seat belts mounted in the back of a 79 crew cab? I don't see any provision for mounting them like they are done for the front seat. (no provision in the shoulder area of the rear pillar on the cab)
I picked up a crew over the weekend and need to get back seatbelts installed before taking the family for a ride.
This thing has seats in it from a conversion van...the front has a retractor on the floor, through a loop at the shoulder b-pillar on the truck (at the factory location) and then down to the receiver which is connected to the seat. (obviously not factory) it works pretty well but cant' do that for the rear.
  #2647
Old 07-28-2014, 02:34 PM
oddfordjunkie oddfordjunkie is offline
oddfordjunkie is gaining momentum as a positive member of FTE.
Rear seats had Lap Belts ONLY.
Either put in Lap Belts, fabricate for adding shoulder belts or get different seats that have the belts in them.
  #2648
Old 07-29-2014, 10:56 AM
thanks oddfordjunkie....i need a 3 point deal for the kiddies...will have to make something work from the c-pillar....doubt it's re-inforced enough since there was no provision there from the factory.
  #2649
Old 07-29-2014, 03:29 PM
Some guys cut the entire "pocket" for the seat belt out of a standard cab and weld that in, others reinforce the area with a piece of plate and put in the style that uses a single bolt on the C pillar and the retractor mounts on the floor.
I scored 3 center seats for 2012 F-150 that have the belts in them so I need to fab a mount and gonna use them as my back seat, then I can put the kid in the middle and drop both side seats which will trap her and give her 4 cup holders and 2 storage compartments.
  #2650
Old 07-30-2014, 02:36 PM
thanks for the info....my seats are nice so they will stay. It looks like some companies make booster seats for up to 80lbs that secure using just a lap belt and then 5-pt harness integral to the booster seat. At $60 they are cheaper than new 3-pt belts.
New question: where to buy the rear door interior straps that mount above the door panel?
  #2651
Old 07-30-2014, 03:18 PM
9thPony's Avatar
9thPony 9thPony is online now
9thPony is starting off with a positive reputation.
Here is what I am doing for the rear seat belts in my crew:
Retrofit Seat Belts Installation Shoulder Bolt Anchor Point Your Classic Car, Hotrod 3 Point Seatbelts
The actual belt I am considering :
http://wescoperformance.stores.yahoo...urst-retr.html
Haven't gotten to the install of these yet, but its on the list.
  #2652
Old 07-30-2014, 08:20 PM
fitzmotor's Avatar
fitzmotor fitzmotor is offline
fitzmotor is starting off with a positive reputation.
I did a post in the regular 73-79 forum about fitting 1995 crewcab power windows and locks in a 75 crewcab, I posted it there as most dent side owners are not crewcab owners and could use the info, so then I thought I would do a reply here for any CC owners who may be interested in the upgrade, it's not super hard, it's cheap and it works great.
  #2653
Old 08-01-2014, 10:06 AM
Installed 3-pt universal seat belts last night in the back. My truck has a roll bar so I drilled a 7/16" hole through that and secured the shoulder loop to it. I mounted the retractor mechanism horizontal instead of vertical...seems too work just fine that way but may change it to vertical in the future and mount the retractor using a clip angle.
Does the aftermarket make the rear door grab straps?
  #2654
Old 08-02-2014, 03:27 AM
Straps are the same as 70s full size Ford cars, I knew I should have wrote done all those bits of information when I read this entire thread.
  #2655
Old 08-03-2014, 07:29 PM
Quote:
Thanks for the info...I will have to do a search and find it.
1977 crewcab cummins build 77_crew 1973 - 1979 F-100 & Larger F-Series Trucks 527 12-23-2016 08:48 AM
Recommended crewcab 4x4 conversion 78SupercabPowerstroke 1973 - 1979 F-100 & Larger F-Series Trucks 9 01-28-2016 02:31 PM
Ordering a truck. How much below invoice can I expect? whalerron 1999 to 2016 Super Duty 18 01-18-2016 04:18 PM
1978 Ford Crew Cummins Swap Higbean Engine Swaps 244 11-29-2015 05:21 PM
69 F250 towing capacity rrawlins 1967 - 1972 F-100 & Larger F-Series Trucks 9 09-04-2003 10:26 PM
Tags
1970, 1973, 78, 8, 90s, bed, cab, crew, doors, f250, f350, ford, lowered, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
