Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #241 (permalink)
Old 05-29-2008, 12:47 PM
ChaseTruck754 is starting off with a positive reputation.
NIIIICE buy dave! Welcome to the club. Now if I could only find the time to actually start my swap. I just gotta get my living and shop situation squared away 1st...
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1989 Ford Ranger = never gonna be done...
1974 Ford F250 4x4 Crew cab = tow rig
1972 Alfa Romeo GTV
1991 Dodge 250 cummins - motor donor
1999 Toyota Tacoma 4wd = daily driver/weekend toy
Sponsored Links
To remove this ad, register today!
  #242 (permalink)
Old 05-31-2008, 12:25 AM
Big billy C's Avatar
Big billy C is starting off with a positive reputation.
CrewCab swap help please
Hey folks, Does anyone have any info on swapping My 79 regular cab F250 4x4 for a 79 F? Crew cab 2 wheel drive. Both have 4 speed's/351m400's. I plan on unbolting front clip, junking both box's and using my dog house cover. Unbolt the master from the booster. I'm not sure If the Crew cab (4door) use's the same 4 bolting locations as the regular cab of the same year. I'm also not sure which wiring harness i should use, reg. cab's or the crew cab's. For the rear mounts i'll be able to get. I've just never done this before basically, and not by myself. Any help would be greatly appreciated !
thanks again.
bill
Sorry just saw the crew cab only thread.
  #243 (permalink)
Old 06-01-2008, 01:06 AM
crewcaber is starting off with a positive reputation.
Crewcab Long Bed Conversion??
Has anyone completed a long bed install on their F250 shortbed crewcab. I have a '78 with a beat up bed and want to lengthen the frame for a long bed. Any info would be great.
  #244 (permalink)
Old 06-01-2008, 08:12 AM
78 4x4 crew cab longbed conversion
I posted this question last night but im new to this and can't even find my own post to see if there was a reply. :-)
I have a 78 crew cab 4x4 with a beat up bed and want to put a long bed on it. The frame will need to be extended i'm sure. But where do you extend the frame. directly behind the cab or extend it at the rear and relocate the axle position via spring mounts moved back on the frame.
Any help would be great, thanks.
  #245 (permalink)
Old 06-01-2008, 08:14 AM
Hey, there it is, I need to sober up...
  #246 (permalink)
Old 06-03-2008, 06:44 PM
johaner78 is starting off with a positive reputation.
Hey fellow crewcabbers - do any of you have a nice audio setup in your trucks? Where have you mounted speakers (front doors, B pillars, C pillars?) What types of speakers did you use? Where did you mount an amp and / or sub?
Any pics would be great to!
Thanks,
Eric
__________________
1996 F150 4x4, 351, auto, LB, K&N Filtercharger, "Silver Bullet"
1978 F250 CC, sb, 4x4 "in the works"
  #247 (permalink)
Old 06-03-2008, 09:04 PM
lostinfords is starting off with a positive reputation.
crewcaber...sent email w/ my email address. i bought 77 crew cab 4x4 w/ frame that was stretched to accomodate 8' bed, will try to send pics to you, send email address.
  #248 (permalink)
Old 06-04-2008, 12:10 AM
Smile
johaner78...I have no sound system in my crewcab, it's bare bones...Sorry. Lostinfords...Appreciate the reply, that would be great if you could send any pitures that you have of how and where the frame was extended to...jeremy.nowak@q.com...Thanks
  #249 (permalink)
Old 06-04-2008, 12:13 AM
Lostinfords...I made a mistake with the e-mail address, it is actually (jeremy.nowak330@q.com)...Late night, rough day...Thanks again.
  #250 (permalink)
Old 06-05-2008, 05:21 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4 is gaining momentum as a positive member of FTE.
i wouldnt cut holes in the pillars for speakers!! the body is so long that it flexes. you could see creases in the exterior skin after a while from the weakened inner pannel. plus, when you go to sell it, someone might get turned off by a hack job. speakers sound so much better when installed into a wood speaker box anyway! not to mention better protected.
__________________
STOP GLOBAL WHINING!
  #251 (permalink)
Old 06-05-2008, 09:42 PM
78_f800 - I know the cabs are long, but do you honestly think that by cutting a 6" hole inside the B pillar panel will cause the 2 1/2" wide panel on the outside of the truck between the doors to crease????? That cab / frame would have to be twisted like a pretzel for that to happen I would think.
I'm more particular about how I do things than what you know - the speakers would be nicely done, not like a lot of hack jobs I see in some of the trucks on this site.
My 96 ford has speakers inside the C pillar as well as the door speakers - they sound pretty good to me. Where would a guy mount wooden speaker boxes for these old crewcab trucks anyway? Hardly any place for an amp or sub let alone wooden speaker boxes that look nicely installed.
Don't want to sound like a jerk but just want to do this correctly and have a great sounding system when I'm done.
__________________
  #252 (permalink)
Old 06-08-2008, 03:29 PM
truck'n in Idaho is starting off with a positive reputation.
Talking
just got my first crew cab today. 1975, rebilt 460, looks like every thing is factory stock except motor same paint and interior will get some pics coming but will swap for disc brakes.very very little rust old guy had it. one owner
  #253 (permalink)
Old 06-08-2008, 11:58 PM
the truck i got my roof panel from had this condition, b-pillars had ripples on the exterior skin from holes cut inside (although it was a well used 4x4) you could reinforce the pillar around the hole like was done for the trucks equipped with shoulder belts. im just trying to caution people so that no one screws up their structural integrity. an idea also i have seen done is if you build a roll cage-build mdf wood boxes and secure them with u-bolts to the upper cage, it works totally awsome, and you get unobstructed surround sound, or build a custom roof panel with speakers overhead. subs will have to be mounted behind the rear seat. if you have the in-cab fuel tank, just build a box to mount to the floor in the back seat, with some cupholders if needed. if you ditch the bench seats, it opens up more room too. and i dont think you are a jerk. oh- and you dont leave them bare wood. glue on automotive carpet, or smooth out and fill screw holes with bondo and paint with hammerite or whatever you like, just like a professional shop would do only for a tenth the cost.
__________________
  #254 (permalink)
Old 06-09-2008, 12:11 AM
am i the only person in las vegas with a pre-1980 crew cab????? i dont even see any old trucks around here anymore- what the heck is up with this town?? everyone has a tahoe and a prius out front this is LAME. common' red necks-move here already!!
__________________
  #255 (permalink)
Old 06-09-2008, 11:42 PM
jhooch's Avatar
jhooch is starting off with a positive reputation.
You think that 's bad? Try the California Bay area! Prius City. Those who don't drive Prius' have BMW's or Saab's.
__________________
Jhooch
'05 Excursion Limited 4X4 6.0 Powerstroke
'77 Bronco 302, NP435
'76 F250 4X4 Crew 360, 4-sp (will be Powerstroke)
'66 F100 4X2 LB Custom Cab 428, C6
'66 F100 4X2 SWB Custom Cab, 352, 3sp.
'62 F100 4X2 LB Custom Cab Uni, 262, 4-sp
'64 Ford Galaxie 500 2dr HT
'63 Ford Galaxie 500 2dr HT
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
