Crewcab Only Thread.
Old 04-29-2008, 02:04 PM
lostinfords's Avatar
lostinfords
lostinfords is offline
I have 2 gasket sets and 1 set of emblems, the other set was either lost, prior to me buying the crew cab , or kept by one of the prior owners as a keepsake, sorry. This truck was actually bought in pieces. What were the emblems from, what year and model??
  #212
Old 04-29-2008, 02:14 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
78_f800crewcab4x4 is online now
Originally Posted by lostinfords
link to pics of emblems
those embelems are off from a 57-60 f700+ truck or a N-series ford, those are bad *** embelems! i want to eventually build one of those trucks. and everyone thinks the superduty name came in the 90's!
  #213
Old 04-29-2008, 02:28 PM
lostinfords
thanks for the info. I am having a senior moment... what are the N series trucks???
  #214
Old 04-29-2008, 04:13 PM
78_f800crewcab4x4
N series- a very tough and tall medium duty truck built from 63-69 (i think) they use the conventional slick-sixties f series cab, and have a different front clip, and even came in a crew cab variety!!
there is a lady that has a site devoted to them,but i cant find it now. YouTube - Ford N series 220 warm up
they also were on T series, and maybe on f series throughout the 60's. here's what looks like your embelems here> https://www.ford-trucks.com/user_gal...186941&width=0
and heres a crew cab> 1967 Ford F550+ 4x2 - N series
i don't have pics of the superduty embelem on the n series, but i have seen it.
  #215
Old 05-03-2008, 12:25 AM
bendog's Avatar
bendog
bendog is offline
Finally got my 76 C/C home, working on it now. How much lift is needed to clear crossover steering? And what type of power steering box is best for the conversion? Thanks.
  #216
Old 05-03-2008, 12:53 AM
jhooch's Avatar
jhooch
jhooch is offline
I'm using a 78 F150 4X4 box with 80-96 internals (so the pitman arm will point backwards and rotate the correct way), I have 3-inch Rancho leafs. Hopefully will clear with Sky Manufacturing's crossover steering. Requires cutting that raised piece on the frame and welding a plate to mount the box. Good luck!
  #217
Old 05-03-2008, 09:36 AM
bendog's Avatar
bendog
bendog is offline
Thanks, I am going to the scrapyard today and hoping to get a box for my build. Will a 79 4x4 box work?
  #218
Old 05-03-2008, 11:21 AM
ChaseTruck754's Avatar
ChaseTruck754
ChaseTruck754 is offline
I plan on using a chebby or dodge saginaw box.
  #219
Old 05-03-2008, 12:16 PM
jhooch's Avatar
jhooch
jhooch is offline
Whatever box you use you will have to do some fabbing. The later boxes all mounted on the inside of the frame while ours were on the outside. My buddy did the 78 F150 4X4 box as mentioned above on his '72 so I know that works. In fact he pirated the box I had custom built for my 76 when his box, which he had pieced together out of wrecking yard boxes, failed. I had mine professionally done by ARI which is now defunct, so now I have to get another one built. I will probably use Redhead in Seattle this time. Best of luck. BTW I 'm orig from K Falls, Ore. Where in southern Oregon are you from?
  #220
Old 05-03-2008, 04:56 PM
RNOVRIT's Avatar
RNOVRIT
RNOVRIT is offline
I figured I would put this here as I know you all appreciate these trucks. I have changed directions in projects and will/are letting the old girl go along with anything that goes with it. She is going as a "parts" truck in one piece. I will place an add in the classifieds later but just wanted to give you all a heads up but most of all I wanted to thank everybody for all the help. I will still be checking in every once in a while.
Thanks again, Rod
  #221
Old 05-03-2008, 11:21 PM
bendog's Avatar
bendog
bendog is offline
Im hailing from Central point, just north of Medford. Good to hear from an ex-local. I just scored a new hood, cab top to repair my crew roof, and most of an air conditioning system and all of the dash and engine wiring out of a 79 bronco. I'll be meeting the bodywork guy monday. I'm hoping to get my crossover, suspension lift and chassis paint and rebuild done before my cab gets back. Is a 150 box strong enough, and does it give alot of additional clearance to put the rearward facing 150 box in instead of a standard?
I'd like to only lift about 3-4 inches, and if that box is better, thats what I'll start looking for. Otherwise I'll just pick up the f-250 4x4 box at my scrapyard, I trust 250 parts more than 150 parts, Especially under a heavy truck. Why are you planning on those boxes in particular, Chase? More clearance? Stronger? Thanks.
  #222
Old 05-03-2008, 11:26 PM
ChaseTruck754
I've seen the saginaw boxes used a lot in a crossover setup. They are easy to find and therefore relatively cheap. They are relatively easy to mount, and have a strong mointing type system. Actually - they are just strong overall!
  #223
Old 05-05-2008, 12:22 AM
jhooch's Avatar
jhooch
jhooch is offline
There really is no strength difference between the boxes. In fact 80-96 F100-350 use the same box. The 77.5-79 F250 4X4's have a different frame so it's not a direct bolt in. I want to eliminate the drag link that runs parallel to the frame. The 77.5 to 79 F250 4X4 box still utilizes this. With reverse rotation using 80-96 internals on a 78-79 F150 box you can mount the box closer to the factory position (albeit on the other side of the frame). It will definetly require the use of a crossover steering type setup. I tried using a standard tie/rod drag link setup but it doesn't clear the spring. My buddy made the standard tie rod/draglink setup work by welding two-inch spacers between his spring and shackle mounts, dropping his springs down, he also bent his drag-link to clear. I prefer Sky Manufacturing's hi-steer crossover setup. If I ever get around to having another box built, I'll post pics of my progress. The truck is still in my backyard with no steering whatsoever!
  #224
Old 05-07-2008, 04:06 PM
76f350spercamprspeal's Avatar
76f350spercamprspeal is offline
Didnt Know they Had SuperDutys Back then?
  #225
Old 05-07-2008, 04:45 PM
BradyCouchman's Avatar
BradyCouchman
BradyCouchman is offline
ok so to tell the truth 2 things - one my CC is a 70 and 2 i didnt look for my answer here before posting sorry about those 2 things, but here goes
did any crew cab 67-79 come 4X4 AND long bed?
Quick Reply: Crewcab Only Thread.
