Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #211 (permalink)
Old 04-29-2008, 03:04 PM
lostinfords's Avatar
lostinfords lostinfords is online now
lostinfords is starting off with a positive reputation.
I have 2 gasket sets and 1 set of emblems, the other set was either lost, prior to me buying the crew cab , or kept by one of the prior owners as a keepsake, sorry. This truck was actually bought in pieces. What were the emblems from, what year and model??
  #212 (permalink)
Old 04-29-2008, 03:14 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4 78_f800crewcab4x4 is online now
78_f800crewcab4x4 is gaining momentum as a positive member of FTE. 78_f800crewcab4x4 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by lostinfords View Post
link to pics of emblems
those embelems are off from a 57-60 f700+ truck or a N-series ford, those are bad ass embelems! i want to eventually build one of those trucks. and everyone thinks the superduty name came in the 90's!
__________________
1978 F600 Bronco 4 door "Centurion"
1958 F700 next "Centurion" project
1973 F350 Crew Cab Special, 460 all race
2002 Excursion Limited 4x4 7.3
Please help them:
http://www.lionconservation.org/index.html
  #213 (permalink)
Old 04-29-2008, 03:28 PM
thanks for the info. I am having a senior moment... what are the N series trucks???
  #214 (permalink)
Old 04-29-2008, 05:13 PM
N series- a very tough and tall medium duty truck built from 63-69 (i think) they use the conventional slick-sixties f series cab, and have a different front clip, and even came in a crew cab variety!!
there is a lady that has a site devoted to them,but i cant find it now.
they also were on T series, and maybe on f series throughout the 60's. here's what looks like your embelems here> http://www.ford-trucks.com/user_gall...186941&width=0
and heres a crew cab> 1967 Ford F550+ 4x2 - N series
i don't have pics of the superduty embelem on the n series, but i have seen it.
__________________
Please help them:
  #215 (permalink)
Old 05-03-2008, 01:25 AM
bendog's Avatar
bendog bendog is offline
bendog is starting off with a positive reputation.
Finally got my 76 C/C home, working on it now. How much lift is needed to clear crossover steering? And what type of power steering box is best for the conversion? Thanks.
__________________
1976 crew cab, 4x4, family tow monster. 97 Dodge Cummins engine doner.
  #216 (permalink)
Old 05-03-2008, 01:53 AM
jhooch's Avatar
jhooch jhooch is offline
jhooch is starting off with a positive reputation.
I'm using a 78 F150 4X4 box with 80-96 internals (so the pitman arm will point backwards and rotate the correct way), I have 3-inch Rancho leafs. Hopefully will clear with Sky Manufacturing's crossover steering. Requires cutting that raised piece on the frame and welding a plate to mount the box. Good luck!
__________________
Jhooch
'05 Excursion LTD 4X4 6.0, '01 F250 4X4 Crew 7.3
'73 Bronco 302 C4, '76 F250 4X4 Crew 360, 4-sp
'66 F100 4X2 LB Custom Cab 428, C6
'62 F100 4X2 LB Custom Cab Uni, 262, 4-sp
'63-64 Ford Galaxie's, 55 Ford Customline 2-dr
  #217 (permalink)
Old 05-03-2008, 10:36 AM
bendog's Avatar
Thanks, I am going to the scrapyard today and hoping to get a box for my build. Will a 79 4x4 box work?
__________________
  #218 (permalink)
Old 05-03-2008, 12:21 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
1974 Ford F-250
ChaseTruck754 is gaining momentum as a positive member of FTE. ChaseTruck754 is gaining momentum as a positive member of FTE.
I plan on using a chebby or dodge saginaw box.
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #219 (permalink)
Old 05-03-2008, 01:16 PM
jhooch's Avatar
Quote:
Whatever box you use you will have to do some fabbing. The later boxes all mounted on the inside of the frame while ours were on the outside. My buddy did the 78 F150 4X4 box as mentioned above on his '72 so I know that works. In fact he pirated the box I had custom built for my 76 when his box, which he had pieced together out of wrecking yard boxes, failed. I had mine professionally done by ARI which is now defunct, so now I have to get another one built. I will probably use Redhead in Seattle this time. Best of luck. BTW I 'm orig from K Falls, Ore. Where in southern Oregon are you from?
__________________
Jhooch
  #220 (permalink)
Old 05-03-2008, 05:56 PM
RNOVRIT's Avatar
RNOVRIT RNOVRIT is offline
RNOVRIT is starting off with a positive reputation.
I figured I would put this here as I know you all appreciate these trucks. I have changed directions in projects and will/are letting the old girl go along with anything that goes with it. She is going as a "parts" truck in one piece. I will place an add in the classifieds later but just wanted to give you all a heads up but most of all I wanted to thank everybody for all the help. I will still be checking in every once in a while.
Thanks again, Rod
  #221 (permalink)
Old 05-04-2008, 12:21 AM
bendog's Avatar
Im hailing from Central point, just north of Medford. Good to hear from an ex-local. I just scored a new hood, cab top to repair my crew roof, and most of an air conditioning system and all of the dash and engine wiring out of a 79 bronco. I'll be meeting the bodywork guy monday. I'm hoping to get my crossover, suspension lift and chassis paint and rebuild done before my cab gets back. Is a 150 box strong enough, and does it give alot of additional clearance to put the rearward facing 150 box in instead of a standard?
I'd like to only lift about 3-4 inches, and if that box is better, thats what I'll start looking for. Otherwise I'll just pick up the f-250 4x4 box at my scrapyard, I trust 250 parts more than 150 parts, Especially under a heavy truck. Why are you planning on those boxes in particular, Chase? More clearance? Stronger? Thanks.
__________________
  #222 (permalink)
Old 05-04-2008, 12:26 AM
1974 Ford F-250
I've seen the saginaw boxes used a lot in a crossover setup. They are easy to find and therefore relatively cheap. They are relatively easy to mount, and have a strong mointing type system. Actually - they are just strong overall!
__________________
1970 Ford F250
  #223 (permalink)
Old 05-05-2008, 01:22 AM
jhooch's Avatar
There really is no strength difference between the boxes. In fact 80-96 F100-350 use the same box. The 77.5-79 F250 4X4's have a different frame so it's not a direct bolt in. I want to eliminate the drag link that runs parallel to the frame. The 77.5 to 79 F250 4X4 box still utilizes this. With reverse rotation using 80-96 internals on a 78-79 F150 box you can mount the box closer to the factory position (albeit on the other side of the frame). It will definetly require the use of a crossover steering type setup. I tried using a standard tie/rod drag link setup but it doesn't clear the spring. My buddy made the standard tie rod/draglink setup work by welding two-inch spacers between his spring and shackle mounts, dropping his springs down, he also bent his drag-link to clear. I prefer Sky Manufacturing's hi-steer crossover setup. If I ever get around to having another box built, I'll post pics of my progress. The truck is still in my backyard with no steering whatsoever!
__________________
Jhooch
  #224 (permalink)
Old 05-07-2008, 05:06 PM
76f350spercamprspeal's Avatar
76f350spercamprspeal 76f350spercamprspeal is offline
1976 Ford F-350
My Garage
76f350spercamprspeal has a very good reputation on FTE. 76f350spercamprspeal has a very good reputation on FTE. 76f350spercamprspeal has a very good reputation on FTE.
Didnt Know they Had SuperDutys Back then?
__________________
-With all Due Respect-
--Anthony-- -*~<-76SCS->~*-
*Anthony's Truck Pictures *Anthony's Truck Pictures-2 *Anthony's Truck Pictures-3
Father's Formally owned-67 F250-69 F250-77 F350-93 E350-*--Join The SoCal Chapter *Here*
  #225 (permalink)
Old 05-07-2008, 05:45 PM
BradyCouchman's Avatar
BradyCouchman BradyCouchman is offline
BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE.
ok so to tell the truth 2 things - one my CC is a 70 and 2 i didnt look for my answer here before posting sorry about those 2 things, but here goes
did any crew cab 67-79 come 4X4 AND long bed?
__________________
1970 F-350 Crew Cab long bed
06 Focus ZX3 5 Speed (DD)
Thinking the Government stimulus plan is working is like thinking that taking water form the deep end of a pool and dumping it in the shallow end will raise the water level of the pool.
SoCal FTE Member
Tags
1970 , 1973 , 78 , 8 , 90s , bed , cab , crew , doors , f250 , f350 , ford , lowered , truck , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
