Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-11-2008, 07:55 PM
green250 is starting off with a positive reputation.
Exclamation rough idle and lean code
I have a 2000 f250 superduty 4x4 5.4 liter.At idle it runs rough and misses.I am throwing a system lean bank 1 code.The rpms fluctuate up and down.While driving it still has a slight hesitstion and power is down with poor gas mileage.I have changed all fuel injectors,cleaned maf,replaced pcv and checked hose for crack/leak.I Also replaced the fuel presure regulator.Fuel pressure is about 38# not running.The coils have been replaced with accels about 7 months ago.just changed the plugs about 2 months ago but going to do it again.Any advice anyone has will be greatly appreciated.Ive already done searches and havent found anything to cure my truck yet.Thanks in advance to any suggestions.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-12-2008, 12:06 AM
Fordfreak_24 is starting off with a positive reputation.
my truck did something similar. there is a plug on the bottom of air filter housing. mine had poped off and was sucking in unmetered air. i had to permitex mine on to get it to stay. that might be something that you'll want to check. good luck
  #3 (permalink)
Old 02-12-2008, 04:57 AM
thanks,i looked and everything is ok with the air filter.
  #4 (permalink)
Old 02-17-2008, 10:20 PM
wilkinda is starting off with a positive reputation.
Mine did the same thing and it was the PCV on the right bank. Changed it out and the problem went away...
  #5 (permalink)
Old 02-17-2008, 11:31 PM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Check the PCV hose elbows. Especially the one connected to the rear of the intake manifold.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #6 (permalink)
Old 03-11-2008, 10:47 PM
FatDutchMn is starting off with a positive reputation.
rough idle
Quote:
Will this rough idle from the PCV have an effect on gas mileage?
  #7 (permalink)
Old 03-12-2008, 11:35 AM
projectSHO89 has a good reputation on FTE.projectSHO89 has a good reputation on FTE.
Quote:
If you have a vacuum leak, one of the most common symptoms is a rough idle (if the leak is large enough).
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
