Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Ranger & B-Series
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 02-11-2008, 04:44 PM
AC94EXPLORER is starting off with a positive reputation.
im getting a 83 ranger
hi i was wondering if anybody can tell me about this 83 ranger 2wd 2.3 motor. i was told it has a newer motor in it has a serpintein belt. they replaced the clutch, slave cyl and clutch master cyl. im looking into drive this truck to cali and bacl cause im moving to there from wa. im not sure if its a 4spd or 5spd. i heard from the owners its really good on gas.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-11-2008, 04:52 PM
RangerPilot's Avatar
<-- Private Pilot
RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.
'83 was the first year of the Ranger.
The 2.3L is well known for being good on gas. The only 4-speed manual was the Toyo 4, so it's probably a 5-speed. You should find out soon though.
Is it carbureted? Be nice if we knew for sure what year the engine was.
  #3 (permalink)
Old 02-11-2008, 05:24 PM
it is carb. owner told me it was a 4 speed.
  #4 (permalink)
Old 02-11-2008, 10:38 PM
i was wondering if these trucks have timing belt or chain? also if anyone know how hard is it to replace the valve cover gasket and oil pan gasket? thanks
  #5 (permalink)
Old 02-11-2008, 10:58 PM
<-- Private Pilot
It has a timing belt, which is quite the PITA to change.
The valve cover I would imagine would be easy on an older engine. The oil pan I've no clue about, hopefully someone else with a 2.3L can chime in on that.
  #6 (permalink)
Old 02-12-2008, 08:17 AM
BSmitty is starting off with a positive reputation.
The oil pan will give you a headache, you'll almost certainly have to lift the engine a little to clear. The valve cover gasket is very easy, just be careful to clean the surface thoroughly before putting the new gasket in, and if you can get a rubber replacement instead of cork, you'll have a better chance of not ripping it. The timing belt idea is a good one, and you might consider installing a new thermostat while you have the timing cover off, it makes the bolt nearest the cover much easier to get to. The TK4 is a great transmission, as long as you keep the fluid fresh it'll serve you well, but still listen to it carefully for signs of abuse/neglect. A truck that age, expect to fix it though, it's 25 years old!
__________________
^Candy^
1985 Ranger 2wd Explorer edition, 2.3l TK5. XL without power steering, brakes, etc.
Daily Driver;
1992 Ranger 2wd 2.3l M5OD, Custom cab with A/C, Cruise, P.S./P.B.
Cardomain clicky
  #7 (permalink)
Old 02-12-2008, 08:27 AM
i was thinking of putting a 5 spd froma 84 ranger should justbolt right up.
  #8 (permalink)
Old 02-12-2008, 08:29 AM
Pablo-UA is starting off with a positive reputation.
I imagine this truck repainted in retro-stile of early 80-s, tranny swaped to 5 st, engine to v6, awd..... lifted a bit...
  #9 (permalink)
Old 02-12-2008, 08:32 AM
there saying this truck is black but its like a dark dark gray color and has the original pin stripes. i wanna keep the truck a 4cyl but wanna put a 5 spd might be a 4spd ihavent checked. i wish i can giv ford my vin# but the truck might be too old.
  #10 (permalink)
Old 02-12-2008, 11:45 AM
jason867's Avatar
jason867 is starting off with a positive reputation.
It's not too old, I gave my 78' f250's vin and they mailed me the results, about 3 months later lol...
__________________
Visit my website for more about my truck! - jason867.webs.com
My baby: 1978 Ford F-250 Ranger 3/4 ton 4x4 400cid
My daily driver: 1997 Ford Ranger XLT 2WD 2.3L 5sp
  #11 (permalink)
Old 05-16-2008, 06:38 AM
BlueOvalLover is starting off with a positive reputation.
Quote:
Hey AC94EXPLORER,
Did you ever find the answer to your question. Would the 5 spd from early Rangers be a direct bolt-in swap?
I also have the 83 with a 4 spd. Seems to be a pretty solid unit, but I have no top end.
__________________
93 F250 XLT, X-CAB, 351W, 5-SPEED
  #12 (permalink)
Old 05-16-2008, 10:16 AM
__________________________________________________ ____________
Seems to me not. You want to use V6 engines. Early ranger with 4-cyl engines had 4st and 5st trannies, that do not fit any v6. All Cologne V6 engines share bolt pattern, but 3.0 and 3.8 V6 have unique bolt patterns.
Cologne L4 and Lima L4 engines have different bolt patterns so tranny swap with special plate is possible, but there early tannies had non-integral belhousings. M5OD has integral bellhousing.
There is one old way to fit any tranny, like T5, silverado tranny and other using A4LD bellhousings mashined for relevant tranny. I did it to fit GAZ tranny to 3.0.
It is a good way becouse there are so many really dead tranniers for any ford engine on JYs nearly for free.
But pay atention to clutch. I had to use flywheel, starter and pressure plate made for Ford and clutch disk that fits this tranny. It is not all, I realised that external slave is better and drilled 2 holes in bellohousing to bolt it on.
Made by Valeo clutch have much longer life then slave.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
