Information on bilsteins - Ford Truck Enthusiasts Forums
Old 02-11-2008, 05:37 PM
Ramblynn Ramblynn is offline
Ramblynn is starting off with a positive reputation.
Hi
I've did a search but can't seem to find what I'm looking for.I have a 2004 screw,4x4.I want to level out the front.Reading this forum has given me two options.
1.Leveling kit 2"
2.Bilsteins that have 0"to 2" built into them.
If these two options ars correct what would be the recommendation?
What would be the right model in the bilsteins?
Any instructions for the front leveling install if I go that way would be good.
Thanks in advance for your time.
Mike
Old 02-11-2008, 11:33 PM
ech0sh4y's Avatar
ech0sh4y ech0sh4y is offline
ech0sh4y is starting off with a positive reputation.
From what I heard I'd run the bilsteins, that way when your factory shocks go you won't have to change them! You can also adjust it if you don't care for the added lift. I went with the 2.6 AS level kit... I with I woulda heard about the bilsteins
Old 02-13-2008, 08:31 AM
FX4Joe FX4Joe is offline
FX4Joe is starting off with a positive reputation.
I only have 9k on my 06 FX4 but I figure at about 20K the stocks should be shot so I will be going with 2" lift of the Bilstiens. The if I need warranty coverage they really can't say that a leveling "kit" caused any issues.
Old 02-13-2008, 09:19 AM
bowhunk1 bowhunk1 is offline
bowhunk1 is starting off with a positive reputation.
I did a lot of research before I install the leveling kit on my truck....I went with the ready lift because its a metal product and with the others which are made of polyurethane I feel that over time they will wear down and begin to make the front end drop....so whatever way you go is only up to you...but just keep in mind that a steel product is always stronger and durable. Just my opinion.
This is the link for the leveling kit for your truck:
http://www.autoanything.com/suspensi...0A2529335.aspx
Quote:
Originally Posted by Ramblynn
Hi
1.Leveling kit 2"
Mike
Old 02-13-2008, 04:59 PM
BirdyMaker BirdyMaker is offline
BirdyMaker is starting off with a positive reputation.
I went with the Bilsteins. They ride stiffer than my stock shocks, but level the truck pretty well. I did mine at 30000 miles and of the 4 shocks that I replaced only one was still any good.
Bilsteins and 2WD Front Leveling kit... ???s F250_ 1999 - 2003 7.3L Power Stroke Diesel 18 11-04-2013 05:04 PM
bilstein 5100's? slowmans 6.4L Power Stroke Diesel 0 11-16-2011 08:16 PM
Help with Bilstein shock selection rcklnhunter 6.7L Power Stroke Diesel 35 05-20-2011 05:53 PM
Bilstein leveling kit installed.....Now ready for lift. jwiebers 2004 - 2008 F150 11 11-15-2010 06:08 PM
Bilstein 5100 preload adjustable shocks. kgilliam80 2004 - 2008 F150 3 03-20-2007 09:56 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
