Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-11-2008, 05:17 PM
SuperSnake's Avatar
SuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to behold
Desk Top Dyno
Any one here have a desk top dyno?
I have my engine in a machine shop and it's going to be rebuilt back to stock spec except for the bore will be 40 over.
Could you please tell me what the displacement will be?
302 ci 40 over,FI and AOD trans rear gear is 3.55.
Thanks
__________________
Cliff
WARNING:
DOES NOT PLAY WELL WITH OTHERS
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-11-2008, 05:40 PM
dragogt's Avatar
dragogt has a very good reputation on FTE.dragogt has a very good reputation on FTE.dragogt has a very good reputation on FTE.dragogt has a very good reputation on FTE.
a 302 w/ .040 over should be about a 308-310 cubic inch.
__________________
92 Isuzu Rodeo 5sp 4x4
87 F150 lwb
83 bronco
86 mustang gt t-top
83 mustang gt
Aaron -STG's - Pirate Investigator
Quote:
Originally Posted by captain p4 View Post
If you can't tell if you have a body lift or not maybe you shouldn't be giving people advice in the offroad forum????
  #3 (permalink)
Old 02-11-2008, 05:41 PM
SuperSnake's Avatar
Quote:
Any Idea what the HP might be?
__________________
Cliff
WARNING:
  #4 (permalink)
Old 02-11-2008, 05:56 PM
dragogt's Avatar
all depends on the heads and cam you dicide to run, are useing flat top pistions? a stock 302 in '85 made about 185hp I think, so your probaly looking at someware in the 200-250 range on a stock build w/ a .040 over.
__________________
87 F150 lwb
83 bronco
86 mustang gt t-top
83 mustang gt
  #5 (permalink)
Old 02-11-2008, 05:58 PM
SuperSnake's Avatar
Thanks the cam and all will be stock wish I could put a stronger one in but I'm just want to get it running. The pistons are flattop with 4 valve reliefs
Thanks for all your help.
__________________
Cliff
WARNING:
  #6 (permalink)
Old 02-11-2008, 06:10 PM
dragogt's Avatar
know what you mean, bit by bit, piece by piece, good luck.
__________________
87 F150 lwb
83 bronco
86 mustang gt t-top
83 mustang gt
  #7 (permalink)
Old 02-17-2008, 07:21 AM
s1120's Avatar
s1120 is starting off with a positive reputation.
Power will be about the same. You will gain more by having a well sealed cyl bore, then you will gain by a few extra CI.
__________________
Paul B
95 Bronco, e40d,5.0HO shortblock, early 351 heads, ported w/1.94/1.60 valves, Crane 2030 cam, shorty headers, homemade Ypipe, and flowmaster cat back[for now]
  #8 (permalink)
Old 02-17-2008, 11:57 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Quote:
Originally Posted by Old Tired Rebel
Thanks the cam and all will be stock wish I could put a stronger one in but I'm just want to get it running..
I dont see your logic.. If you're buying a cam anyway it shouldn't cost you any more to get a better than stock replacement.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's, FRPP Mass Air, TweecerRT 282HP
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
  #9 (permalink)
Old 02-17-2008, 02:18 PM
SuperSnake's Avatar
Quote:
I'm not buying a new cam the cam comes in the master rebuild kit.
__________________
Cliff
WARNING:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
