6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Higher pitch engine sound
Old 02-11-2008, 02:46 PM
ab257z's Avatar
ab257z
ab257z is offline
So we were finishing up a 500 mile ski trip in N/E PA (handled great in the snow) with our 08 350 with a 4,000 lb camper on board, climbing up the hill into the development, and when I accellerated up the hill, the engine sound changed from its normal deep growl to a higher pitched 'tinny' sound. It stopped when i let off the throttle a little, and came back when I accellerated more. Abrubt change in pitch. Like from a A below middle C up to a D sharp.
Anyone else experience this? Should I be worried (my first diesel, so the noises are a little strange to me)? No loss of power, wasn't in regen, wasn't shifting (rpms were constant). Temp gauges all OK right in the middle.
Was the EGR doing something funny?
Have about 2,000 miles on the truck, it was running about 30 psig boost going up the hill, the temperature had dropped to about 6 degrees F. Had just gone down a long steep hill in tow/haul about 5 miles back.
Old 02-12-2008, 08:40 PM
oltrucker's Avatar
oltrucker
oltrucker is offline
it was probably the turbo whistle you heard. it is normal.
Old 02-12-2008, 09:05 PM
SouthTexasDiesel's Avatar
SouthTexasDiesel
SouthTexasDiesel is offline
Yea, probably just the turbos spooling up to carry the weight over the hill.
Old 02-13-2008, 08:13 AM
ab257z's Avatar
ab257z
ab257z is offline
Thanks for your help, but it wasn't a gradual increase, it was more like a switch was turning something on or off, or a gate opening and changing the sound.
Out of town right now, so I will have to take it out this weekend and see whats up. Covered with mud now from the road treatment in PA - we were on the Rt 80 Sunday about 5 miles away and about 3 hours after the 62 car pile-up on Rt 81 near Hazleton due to a snow squall.
Old 02-13-2008, 02:42 PM
rmosso1's Avatar
rmosso1
rmosso1 is offline
I think your electric fan kicked in. Mine has a similar sound on a steep grade. Are you running with a grille cover? Your engine compartment temps will rise faster with a grille cover, even in cold snowy weather. If you have an EXT temp gauge run with it on, and see if it increases when you hear the sound. Proof of the fan kicking in.
Old 02-13-2008, 03:35 PM
OPTITRADER66's Avatar
OPTITRADER66
OPTITRADER66 is offline
My Truck Makes A Higher Pitch Clicking Sound Right Before It Upshifts To A Higher Gear .and It Is Always Right Before It Goes Into A Regen Cycle . But After The Regen It Is Fine Again .
Old 02-14-2008, 03:38 AM
SouthTexasDiesel
The larger turbo is a variable turbo. Which means the vanes in it can adjust to give the appropriate amount of boost w/o requiring higher RPMs. These trucks can produce a lot of boost very quickly. It can go from 10 psi to 30+ psi in about 2 seconds.
mtpiper
05-15-2015 11:58 AM
grullman
10-08-2012 07:18 PM
seattlem45
1999 to 2016 Super Duty
06-04-2010 08:13 AM
Mr.Russell
2004 - 2008 F150
08-07-2008 10:20 PM
snegri
1997-2006 Expedition & Navigator
08-30-2003 09:57 AM
Quick Reply: Higher pitch engine sound
