Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #91 (permalink)
Old 03-05-2008, 10:13 PM
cookie88's Avatar
cookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to behold
Quote:
Originally Posted by tazo
Isn't it nice to moderate in a good way! If you want to add something how about a little Bio in your truck? And then let us know how you like the smell.
It is indeed.
I run B5 about every 4th or 5th tank. The problem is it's 28 miles (round trip) out of the way, and is $.20 per gallon higher. But I still do it on the "every little bit helps" mentality. As soon as somebody local, or at least on my normal route picks it up I will run it all the time.
__________________
Scott - FTE moderator
01 F-250 Lariat, 7.3, ZF-6, NV271, -38R, SII splits, DI tunes, Custom fuel, 5" stacks, IDM140....and more little mods than I can remember.
79 Bronco- 7.3 IDI diesel project truck - AWM
Sponsored Links
To remove this ad, register today!
  #92 (permalink)
Old 03-05-2008, 11:28 PM
FARM69's Avatar
FARM69 is gaining momentum as a positive member of FTE.
Phyd, I checked into the Camelina. It appears that this "weed" has adapted fairly well like its other brothers in the Mustard family. However, compared to "crops" this plant basically has an unknown status." I searched for quite a bit and different find much on it reguarding agronomic material.
I talked to some of my grad professors about it. After searching through the archives for a while we found some informaiton on the sativa. We discussed possilbly getting a test plot going. However, still clueless on how to sow this stuff. Did you hydro-seed it or what? Surely you can't broadcast this stuff???
One thing that really surprised me was the seeds per pound. How the heck did you sow this for your test plot? Somewhere between 350,000 to 450,000 IIRC.
Also, for you older gentlemen, how are the prices now comparing to the prices back in the seventies during the embargo? Are concerns/opinnions similar now as to what they were back then? Just curious.
__________________
97' F250HD 4x4 Intercooled Powerstroke 5 Speed LB / Stage II (180cc) Injectors / 10 K / 5er
A-Pillar AutoMeter Cobalts [Boost, Pyro, Water Temp]
4" Straight / EBPV Exhaust Brake / 6637 / CCV / 203 Stat / HX50 (19cm) is being mounted!!
  #93 (permalink)
Old 03-06-2008, 01:08 AM
Phydeaux88's Avatar
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Fabman would be the one to talk to about that. He has a crop in the ground I don,t yet
__________________
1996 F250 4X4 Crew Cab: Diablo Flip Chip, Powershot 2000, Hypermax exhaust turbo back, Tymar AIS, All the gauges, Bilstein Shocks, AirLift Super Duty bags on the rear
  #94 (permalink)
Old 03-06-2008, 10:08 AM
fabmandelux's Avatar
fabmandelux has a great reputation on FTE.fabmandelux has a great reputation on FTE.fabmandelux has a great reputation on FTE.fabmandelux has a great reputation on FTE.fabmandelux has a great reputation on FTE.
Broadcasting is the only way to seed camelina. I am paying $1/pound for seed this spring, and it only requires 1 pound /acre! Minimum tillage is required, but it should be seeded BEFORE March 1st. I contracted out my seed crop at $.18 per pound FOB my ranch, so the price is comparable to Canola with a lot less input.
I have quite a few links to camelina studies, I'll try and post them later on today.
__________________
FABMANDELUX.
Don.
To join the Oregon Chapter, click HERE
  #95 (permalink)
Old 03-06-2008, 11:18 AM
FARM69's Avatar
Thanks fabman. I would like to get a plot going over here. Although, time will be a major problem in a about a month.
I figured broadcasting would be the only option. The side of this seed is rediculous. A few people tried Canola a fews back in my area and it fell on its face. It would be nice just to how Camelina sativa would do though.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
