Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #481 (permalink)
Old 03-26-2008, 01:03 PM
rbaker6336's Avatar
rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.
this is the one I was going by
http://www.taxadmin.org/fta/rate/mf.pdf
this one better explains it with sales tax
http://www.newyorkgasprices.com/tax_info.aspx
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install
DooDad???=(dfuser ram air)
'98 Grand Cherokee
'86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
Sponsored Links
To remove this ad, register today!
  #482 (permalink)
Old 03-26-2008, 01:10 PM
Markadeck's Avatar
HATES ANY TERRORIST---->>
Markadeck has a great reputation on FTE.Markadeck has a great reputation on FTE.Markadeck has a great reputation on FTE.Markadeck has a great reputation on FTE.Markadeck has a great reputation on FTE.Markadeck has a great reputation on FTE.
[quote=rbaker6336]this is the one I was going by
http://www.newyorkgasprices.com/tax_info.aspx[/QUOTE]
Probably put out by that little known office in Albany known as the Department of Creative Taxation. Don't laugh, it actually exsists.
__________________
Mark
Above car featured in Sept. '83 Super
Stock & Drag Illustrated. No longer mine.
1999.5 F-250 2x4 Extended Cab Long Bed
209,351+miles
6637 Mod
4 inch SS Straight Pipe
DP Oh Boy! Need I say more?
PhD In Common Sense & Logicality
University of Hard Knocks
  #483 (permalink)
Old 03-27-2008, 08:29 AM
Dukernc's Avatar
Dukernc is starting off with a positive reputation.
ANOTHER SURPRISE!! Diesel went DOWN again today.. Yes.. Down even more from $ 3.999 to $ 3.899. With Spring officially here and the demand for #2 fuel oil should hopefully start to go down and this allow for diesel production to go up!! The price of crude has also come down so time will tell! Let's just hope.. We still can can't we?? :-)
__________________
Regards,
Dukernc
1999 F350 CC Lariat Dually LB 7.3L PSD, 4.10LS, ZF-6 w/LuK clutch, 4" MagnaFlow SST turboback exhaust w/5" tip, LINE-X Bedliner
1990 F150 Reg Cab XLT Lariat 4X4 SB 5.0L EFI, 3.55LS, Modified AOD w/auxiliary cooler, cat back, all around farm truck
  #484 (permalink)
Old 03-27-2008, 09:26 AM
cgl cgl is offline
Diesel Lover
cgl is starting off with a positive reputation.
Sadly this lowering trend hasn't hit my area yet. Up to $4.31 from $4.27. Other stations holding tight at $4.19 . 87 is $3.49
__________________
2002 F-350 XLT 4x4 PSD 6spd SC SB SRW
2" Level; Sirius Equipped; 4" StraightPipe; DiPricol Optix; DP F5; EBPV Brake; Foil Delete; Disabled Waste Gate (sometimes); OverBoost Annihilator; Fogs w/ Parks; EBPV LED, DieselSite Billet T-Stat Housing
2007 Polaris RMK 600HO 155
2008 Ranger XL 5spd 4x2 I4 Commuter (27 MPG)
-Rich
  #485 (permalink)
Old 03-27-2008, 09:48 AM
empiretc's Avatar
empiretc has a good reputation on FTE.empiretc has a good reputation on FTE.
$3.759 is the cheapest around here - at one of the few diamond shamrocks left.
use this for your area:
http://www.automotive.com/gas-prices/results.html?zip=
__________________
David
1999.5 (05~07 looks) CrewCab ShortBox 2WD - 190k
6637; A/C Valve; Sonnax; SS HPX; Muffler Delete; Pyro/Boost/Trans/Water/Volt/Fuel & Oil pressure; DP 80HP Econo; Hutch; Harpoon; Stancor GPR w/ LED; 16" Pusher Fan; Tekonsha Prodigy; Kleinn 500 Air Horns
Running on Homemade BIO
  #486 (permalink)
Old 03-29-2008, 11:57 AM
Markadeck's Avatar
So much for the slight downwards trend. Went back up overnight. By the way, how's global warming doing in your neck of the woods? It is downright chilly and raining here. About 20 degrees below the 120 year old average for March 29th.
__________________
Mark
209,351+miles
6637 Mod
  #487 (permalink)
Old 03-29-2008, 12:40 PM
rbaker6336's Avatar
pretty warm here in the 80s
__________________
Ray
'98 Grand Cherokee
PAA #35
  #488 (permalink)
Old 03-30-2008, 12:23 AM
liftedgrocerygetter's Avatar
It's alright 2B Lil Bitty
liftedgrocerygetter has a great reputation on FTE.liftedgrocerygetter has a great reputation on FTE.liftedgrocerygetter has a great reputation on FTE.liftedgrocerygetter has a great reputation on FTE.liftedgrocerygetter has a great reputation on FTE.
Station next to my house is holding onto the $4.09, it has been that way for over a week.
Spring is finally here!! It is still 77 degrees here in Gilbert, Az at 9:20pm.
__________________
Cris
2001 F-350 lariat 4x4, cc lb, 6.5" lift, 35's, lateral traction bars, zoodad, mag-hytec rear diff and trans pan, 4" turbo back exhaust, SCT X3 with 80 econo from DP, guages, foil delete, 6637 w/ cover (Thanks Pete), Bilsteins
PAA #18
  #489 (permalink)
Old 03-30-2008, 01:11 AM
spence13e's Avatar
spence13e is starting off with a positive reputation.
dang co-op keeps bouncing all over the place. they were down to 3.84 from 3.96 for a day or two, then 3.92 and up to 4.02 as of this morning. everywhere else is 3.99 still, although found a station on the south side of town for 3.89. and sadly, this town isn't one of the most expensive places in the state, everywhere is this high.
  #490 (permalink)
Old 03-30-2008, 01:47 AM
Islander1 is starting off with a positive reputation.
Still
Diesel here is US$6.20 a US Gallon.
Dunno what you all biatch and moan about - our only saving grace is that our propane is cheaper than yours!
We would have been paying over $6 a gallon for the last year now most likely...
Probably bought at least 4000 gallons in the last 6 months...
Just get used to it, them camel jockeys need to squeeze us this tight.......don't they?
Hey - maybe we shoulda invaded Saudi instead of Iraq - after all - most of the 9/11 terrorists WERE from Saudi Arabia - and they Do seem to have most of the middle east oil.....
Maybe if we turned Saudi into a glass bowl parking lot as a message to the rest of OPEC - we could then afford to live with reasonable energy prices?.
I for one got sick of the high oil proce a LOoong time ago!
Thats why we have the big red button isn't it - to issue ultimatums to towel headed camel jockeys and have them say yes sir?
About damn time someone pushed one a them big red buttons if ya ask me!
Seems people the world over have forgotten the lessons the mayors of Nagasaki & Hiroshima learned the hard way........maybe it's time a little history revision lesson was handed out..for those in the middle east with memory attention deficit disorder.
Cheers
  #491 (permalink)
Old 03-31-2008, 03:35 PM
cgl cgl is offline
Diesel Lover
Quote:
I think the outcome of that wouldn't be as pleasant as we'd hope... MAD comes to mind. Although I'm not disagreeing with you one bit!!!
__________________
-Rich
  #492 (permalink)
Old 03-31-2008, 03:42 PM
Markadeck's Avatar
Quote:
Sure would solve a lot of problems. I'm all for giving a 1 year notice to anyone that does not want to stay get out, cuz we're gonna build a big wall around the USA and no one is coming or going. Unrealistic I know, but it would be nice. We have all we need right here, and if the goofballs like Moveon.org don't like it, they have a year to pack their bags.
__________________
Mark
209,351+miles
6637 Mod
  #493 (permalink)
Old 03-31-2008, 04:17 PM
jeff7825's Avatar
jeff7825 is gaining momentum as a positive member of FTE.
Filled up at $3.799 today.
__________________
Jeffrey
2001 Ford F-250 Lariat CC SB 4x4 7.3 Powerstroke Diesel
Dipricol gauges-EGT, Boost, Trans. Temp, GPR LED, Ford AIS Intake, Zoodad, Dieselsite coolant filter, AIH Delete, SS HPX, 4" MKO exhaust, DP Tuner
  #494 (permalink)
Old 03-31-2008, 05:13 PM
Markadeck's Avatar
My last post has been bothering me. Not really a good idea I suppose, but I'm just in a down mood anyway, must be the weather which sure sucks where I am right now. Although Japan did get away with isolation for a long time and did just fine with it, then they got involved with the world and get the chit kicked out of them.
__________________
Mark
209,351+miles
6637 Mod
  #495 (permalink)
Old 03-31-2008, 06:07 PM
haulingboat's Avatar
haulingboat is starting off with a positive reputation.
Light Crude needs to be removed from the commodities market if you want to see prices go down. Investors (including myself) are weary about keeping money in traditional stocks. Many have sold their company stocks and reinvested in commdities (seekin shelter), driving the price of goods higher. You (or anyone) can invest today in light crude deliveries for May. Today crude closed at $102 and change for delivery in May. That means not we're not goint to see much of a break thru then, atleast.
Heating oil demand will drop and that will help close the gap between diesel and gasoline, but as long as we are around $100/barrel we will pay $3 plus per gallon.
The low value of the dollar, the credit crunch (created by selling homes to people that could not afford them), and consumer fear are driving the price of light crude and in turn diesel/gas.
We need a nationist in office to turn the ship around, someone interested in helping our nation regain its might. Government health care, increased taxes, more regulation will increase the spiralling debt and consumer woes. It will make them worse. This inturn will force the dollar lower and in turn send more people seeking the security of commodities (driving prices for goods higher).
We need someone willing to make difficult decisions about our spending policies. Bush's war, the Republicans spending habits, and our (the publics) blind eye have all helped create this mess. Democrats are no better, in fact worse. They want to end the war so they can take the money (borrowed money, which we don't have) and spend it on socialist programs. Once they start, they never end, ie. social security, welfare, ect.
We are selling our children and grandchildren down the river so that we can have anything we want now. Our choices in the upcoming election are left, lefter, leftest. None of the candidates have policies that will resolve the current situation.
We need someone willing to cut programs, stop spending, encourage American company growth (by encentive to buy american in america), and buy back some of the T bills from the Chinese.
So, if you want to do something about fuel prices,(food prices, car prices, etc) strikes and boycotts are the wrong direction. You were granted the right to vote for situations just like this.
Lobbiests, banks, and politicians have created this issue while we ignored them and went about our daily lives. Now it is time to pay.
This nation is facing some tough choices. We can continue to delay decisions, wait to fix problems, pile more debt onto our kids, or we can start making sacrifices.
Unfortunetly at this time we only have the choice of whom will give us the least or the most.
Show me someone willing to start taking programs away. I'll show you the man that will help lower fuel prices.
__________________
Thomas
2002 F250, Lariat, 4X4, CC, SB, 4" Superlift, 35" BFGs, 6 position DI Tuner, AFE stage II, Magnaflow SS Exhaust, Fumoto, Intank & PrePump, Autometer Gauges,HPX,Harpoon, DI Tranny w/Precision Industries TC.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
