Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-11-2008, 12:55 PM
CSFord is starting off with a positive reputation.
Question 2001 Ford Escape XLT V6Tire Size
My tire size is 235/70/16 !
Can I use 245/70/16 ? I can get an excellent set from a friend.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-11-2008, 03:28 PM
tcesni is new and has a neutral reputation at this point.
Probably. The key is whether a 245 tire will fit on a 7" width wheel. I used to have 245 tires on my 1988 Mustang and I think it had 7" wheels. A tire dealer can tell you for certain. The 245 tire will be a bit taller than your 235 tire (29.50 inches versus 28.95 inches). This will affect you speedometer and odometer by a small amount.
  #3 (permalink)
Old 02-11-2008, 06:17 PM
YoGeorge is gaining momentum as a positive member of FTE.YoGeorge is gaining momentum as a positive member of FTE.
They'll be fine....
Quote:
Ive run 255/70 x 15's on 7 inch wheels on at least 3 or 4 trucks or vans I've had over the years--hundreds of thousands of miles (they were a traditional substitute for 235/75's). The speedo will under-read by a couple percent, and the gas mileage will *seem* a bit worse if you use the odo readings, but in reality, the slightly longer gearing may actually help mileage (but offsetting in the other direction is the tread width). The slightly greater width may have a bit more lateral movement (side to side "slop") in terms of handling, so not good for autocrossing.
Hell, the tires are only gonna be 10 mm wider than what you have.
George
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
