View Poll Results: What's your MAX boost?
< 25 psi
27
14.44%
25-27 psi
50
26.74%
28-30 psi
73
39.04%
31-35 psi
29
15.51%
> 35 psi
4.28%
Voters: 187. You may not vote on this poll
#76
#78
You guys have to keep in mind your digital gauges might not be too accurate. Chips lie to the computer so it'll read low boost, the same reading that some of the chips display on the monitor. Just because it says you only have 24 psi doesn't mean that's all it's pushing. I drove a dodge the other day with the edge juice w/attitude display and a mechanical boost gauge. they read the same up to mid 20's then the Edge didn't go higher, but the mechanical read up to 44psi. Just keep in mind a good mechanical boost gauge, or stand-alone gauge is much more reilable than the one reading manipulated info from the chip...
#82
I wonder why all you guys boost so much more than me? I have requested and asked my SCT custom tuners to add more boost, but they reply it is already maxed out.
I know that if you are still running EGR than you typically see more boost. But most SCT tunes disable the EGR.
Comments?
Thanks.
Comments?
Thanks.
#83
Comments?
Thanks.
Comments?
Thanks.
#84
Or sticking turbo veins. It's been my experience over and over that anything over 32-34 with a stock turbo is totally useless. You actually start losing power and gaining EGT's because the turbo "chokes" and doesn't move the air...it's simply backing up so to speak.
chris86924
02-15-2016 06:43 PM
03 harley davidson
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
01-16-2016 02:59 PM
