429 or 460? - Ford Truck Enthusiasts Forums
429 or 460?
Old 07-20-2000, 04:30 AM
FE427TP FE427TP is offline
FE427TP is starting off with a positive reputation.
429 or 460?
Old 07-21-2000, 06:54 AM
bigsteve bigsteve is offline
bigsteve is starting off with a positive reputation.
429 or 460?
I got to looking at my pistons,and they have the number 429 stamped on them.When I brought the truck,I was told that the engine was a 460.I have the numbers that are stamped on the block....3Y144749 on rear.......3F21T on the front.Or is the head numbers what I need to know what I have? Trying to learn! Thanks!
Old 07-29-2000, 01:11 AM
Paul Williams Paul Williams is offline
Paul Williams is starting off with a positive reputation.
429 or 460?
Sounds like you have the heads off....The easy way to tell is by measuring the stroke...... 3.85" for a 460 and 3.59' for a 429 Hope this helps Paul
Old 07-29-2000, 01:58 AM
TBirdGuy TBirdGuy is offline
TBirdGuy is starting off with a positive reputation.
429 or 460?
It's possible for you to have either. The bore for both motor's is the same. Only way to tell is the stroke and pin height on the piston. Some people put 429 pistons in 460s because the allow for higher compression. Good luck.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
