More compression out of 460 - Ford Truck Enthusiasts Forums
Old 07-19-2000, 12:05 PM
bigsteve bigsteve is offline
bigsteve is starting off with a positive reputation.
I would like to get more compression out of my 460.Putting 429 pistons (standard) should do it.?What else must be changed?And are there any block huggers for a 78 460.If not how much cutting will need to be done with standard headers like Dynomax? Thank you all!
Old 07-20-2000, 04:30 AM
FE427TP FE427TP is offline
FE427TP is starting off with a positive reputation.
I dont really know 385 series engines, but I'd try putting on the 71 or earlier heads from a 460 before i put 429 pistons in it, they had smaller combustions chambers and are more likely to fit in the block than 429 pistons, but again, I dont know the differences between 429 and 460 psitons, it's a matter of compression height more than bore size or anything
Old 07-20-2000, 08:32 AM
DeenHylton DeenHylton is offline
DeenHylton is starting off with a positive reputation.
You need to stick with a 460 piston and rod...if you use a 429 piston the piston will actually have the head sticking out of the block with the longer stroke of the 460 crank. Anything above 9.5 to 1 compression will be on the verge of detonation with todays gas. You might be able to run 10 or 10.5 to one compression but will have to retard the timing which in effect will lose the horsepower you were trying to gain.
Old 07-20-2000, 09:17 AM
chilly460 chilly460 is offline
chilly460 is starting off with a positive reputation.
The 429 and 460 use the same rods so the piston is made differently to deal with the extra stroke on the 460 so it's not a good idea to use them. If you don't want to go through the expense and trouble of getting the early style heads, just get yours milled. Milling will decrease the combustion chamber size, as well as helping to unshroud the valve, a big power improver. Check with the machinist to see what is a safe cut and how much compression you'll pick up, I think a full point gain is possible.
Old 07-20-2000, 12:45 PM
loosemoney loosemoney is offline
loosemoney is starting off with a positive reputation.
Check my reply in the performance section that you posted...Dave.
Old 07-27-2000, 08:18 PM
Steve_Uzi Steve_Uzi is offline
Steve_Uzi is starting off with a positive reputation.
Old 08-01-2000, 11:13 PM
TBirdGuy TBirdGuy is offline
TBirdGuy is starting off with a positive reputation.
Just to add my own opinion, get a set of older closed chamber 460 or 429 heads. Only difference between a 429 and a 460 is the crank and the pin height on the piston. That's it. Everything else is the same. Getting an older set of heads (i.e. part # DOVE-C) That would up the compression to about 10 - 10.5:1 and would yeild a signifacant increase in horsepower. You could still run on pump gas, would have to be premium but it would run fine. A friend of mine has a 1974 F-250 4x4 with a BUILT 460. He's pushing at least 10.7:1 compression with older style heads and he just runs premium gas, never spark knocks, plugs are always proof of it burning totally. That's the best and easiest way to gain what you want if you ask me.
Tags
1974, 460, compresion, compression, ford, head, height, piston, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
