Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-11-2008, 10:31 AM
ducktalker is starting off with a positive reputation.
whats binding up in the rear end of my truck
I just bought my truck and have noticed when i back up and turn the rear end will click and act like something is binding up.Im new to the ford and diesel world. It has me a little concerned. Has anybody had this problem? Any help would be great.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-11-2008, 10:52 AM
Red Monkey's Avatar
Red Monkey is starting off with a positive reputation.
Is your truck a 4x4? If so the hubs may be 'locked-in' or not unlocking properly and this will cause it to act like something is binding when turning and backing up. Hope that is all it is, good luck.
Hal
__________________
01 F250 7.3 4x4 6637 air filter mod, CCV mod, pyro, EGT & boost guages, 4" turbo back, door molding mod, F5 DP-Tuner.
89 Toyota 4Runner SAS, Marlin Crawler hy-steer, Marlin Crawler Ultimate dual t-case, 5.29 gears, Toyota electric locker front, Detroit locker rear, 4 wheel disk brakes, t-case e-brake, full roll cage, Warn 8274, 22Re 5 speed.
  #3 (permalink)
Old 02-11-2008, 10:56 AM
rbaker6336's Avatar
rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.
it's the clutches in the rearend disengaging, is it dual or single wheel?
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install
DooDad???=(dfuser ram air)
'98 Grand Cherokee
'86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
  #4 (permalink)
Old 02-11-2008, 10:59 AM
yes it is a 4x4. The hubs have auto lock and a lock setting. they're in the auto lock right now. Any suggestions?
  #5 (permalink)
Old 02-11-2008, 11:00 AM
single wheel
  #6 (permalink)
Old 02-11-2008, 11:02 AM
rbaker6336's Avatar
Quote:
Originally Posted by ducktalker
single wheel
you may need a little more friction modifier
__________________
Ray
'98 Grand Cherokee
PAA #35
  #7 (permalink)
Old 02-11-2008, 11:25 AM
Red Monkey's Avatar
ducktalker,
Just because the hubs are in the 'auto' mode doen't mean they are un-locked. Look under the front of your truck just behind both front wheels and you will see the front axle joints, one on the left and one on the right. If your hubs are unlocked you should be able to turn both the left and the right axle joints by hand. Also, with the ignition switch on but the truck not running you should be able to hear the front hubs lock and un-lock when you push the 4x4 button, that is unless you have a vacum leak...
__________________
  #8 (permalink)
Old 02-11-2008, 11:27 AM
thanks ray, ill look into that
  #9 (permalink)
Old 02-11-2008, 12:19 PM
thanks red, ill check on that as well
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
