Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 02-15-2008, 09:17 AM
iridium is starting off with a positive reputation.
Quote:
Originally Posted by northerndave
you're probably ok iridium,
forgive me for asking but, does your steering shaft have a rag joint & if so have you checked that?
(belted rubber joint)
thick black rubber sandwiched in plates/studs/bolts, little smaller around that a beer coaster?
yeah it has a rag joint. It looked ok and there wasn't any play in that joint so I figured that it did not need replacing. Was that wrong?
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 02-15-2008, 09:24 AM
northerndave's Avatar
northerndave is starting off with a positive reputation.
no, you'd know if it was bad by inspecting it as you stated you did.
It was just a thought.
if you were spinning the inlet shaft as much as you said with no movement of the pitman arm I'm sure you are probably right by tightening up the meshload screw/stud.
But I'm no expert on it, luckily there are experts here on the whole steering box topic.
funny Dennis hasn't chimed in yet.
  #18 (permalink)
Old 02-15-2008, 11:13 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.
C9UZ-3A525-A .. Steering Coupler (Rag Joint) is still available from Ford.
From FTE sponsor Direct Ford Parts (Gaudin Ford-Las Vegas NV) Suggested retail price: $75.00 / FTE member net: $53.01
Fits: 1969/74 F100/250 2WD / 1969/74 F350 / 4WD IS DIFFERENT!
NAPA sells a rebuilt box, but "rebuilt" mainly means resealed. Most of the rebuilt gearboxes...by now...are only good for a year or so.
The REAL problem with these gear boxes is addressed by Red Head by installing the bearing in the housing that Ford left out.
The seal kits are available from Ford, NAPA...other parts stores.
F3AZ-3E502-A .. Input Shaft Seal Kit & D7AZ-3E501-A .. Sector Shaft Seal kit..
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
