Help for new Ford Guy - Ford Truck Enthusiasts Forums
Old 07-21-2000, 12:46 AM
bigblockbill bigblockbill is offline
bigblockbill is starting off with a positive reputation.
I have a 74 Ford F100 with a 460. I think the motor came from an 87? Lincoln or Merc.
I have looked in the PAW inserts in Hot Rod Magazine for rebuild kits and, depending on what you need, there are up to 4 choices available for the 460. Your options can range from year to year and even month of the year. Should I even bother with rebuilding this motor or scrounge the junkyards and find a 68-72 Lincoln/Merc and yank out the 460? I am on a tight budget but will be throwing misc speed parts in. I love to find power through head work.
That brings me to my next question. Can I decode the block for the date it was made and rebuild it.....and THEN find some of these "DOVE" heads and throw them on there? OR can I have the heads that are on it ported polished and shaved with over sized valves and have something BETTER than the doves?
Thanks
Bill
Old 07-27-2000, 03:04 PM
Chuck P. Chuck P. is offline
Chuck P. is starting off with a positive reputation.
For what it's worth-check the post on BIGSTEVE's ?-429 block ID. D0VE heads have LARGE ports and valves but still need port work done to gain performance-these also have small chambers 72cc as compared to later with 92-95cc. Police Intercepter heads are the best, so I've been advised-however, just try to find a pair! These have small ports, large valves and small chambers-the perfect combo for torque and horsepower!
Old 07-29-2000, 01:04 AM
Paul Williams Paul Williams is offline
Paul Williams is starting off with a positive reputation.
I think the DOVE heads are a real good place to start.... IIRC there are several different models of these heads....DOVE-A, DOVE-B, DOVE-C I have the "C" type heads on my 429....Can anyone shed some more info on these heads? Paul
Old 07-29-2000, 10:12 AM
TheFonz TheFonz is offline
TheFonz is starting off with a positive reputation.
Have you tried www.naparts.com. They seem to have better prices and good selection on engine kits. I've bought several kits for SmallBlock Fords and InlineSix Fords. I'm getting ready to overhaul a BigBlock Ford and definitely will order from them again. I've been building on the performance side and am very pleased with what I've built. For eight dollars more you can upgrade your kit with Fel-Pro gaskets and depending on the application you can also upgrade the camshaft. Hope this helps.
TheFonz
Old 08-07-2000, 08:45 PM
TBirdGuy TBirdGuy is offline
TBirdGuy is starting off with a positive reputation.
First of all, to the best of my knowledge, Ford only put the 460 in trucks and vans in the late 80's. Actually, I'm pretty sure that Ford stopped putting the 460 in passenger cars in the late 70's. I'm not positive on that, but pretty darn sure. As far as rebuilding your motor, I'd keep your block and just see if you can locate a set of the DOVE heads. That would be your easiest way to upping the performance of your motor without spending an entire paycheck. Hope that helps.
Rob
"Stuck with a m*par, Settle for a ch*vy, Happy with a Ford!!!!"
Old 08-09-2000, 02:07 PM
mudhopper2 mudhopper2 is offline
mudhopper2 is starting off with a positive reputation.
questions about DOVE heads f100reborn Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 03-17-2005 09:32 PM
78 460 ford with 1969 429 dove heads seifertt Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 10-20-2004 12:41 PM
DOVE A2A heads with peanut plug? cabman2 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 09-22-2003 02:19 AM
1970 460 kjrf100 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 10 06-26-2001 07:09 AM
460 heads mattb 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-28-2000 09:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
