429scj mounts
Old 07-25-2000, 10:54 AM
mfunk's Avatar
mfunk
mfunk is offline
429scj mounts
I am having trouble finding mounts to fit my 1970 429scj into my 1975 F250.
can anyoune give me any information??
Old 08-03-2000, 11:16 PM
TBirdGuy's Avatar
TBirdGuy
TBirdGuy is offline
429scj mounts
You probably need to find a set of mounts for a 460 that fit up to your truck. Externally the 429 and 460 are the same. ONLY difference between them is the stroke and pin height on the piston. The only difference I'm aware of between a standard 429, 429 Cobra Jet, and a 429 Super Cobra Jet is the cylinder heads. Therefore, if you get motor mounts for a 460 (which I'm sure have to be kinda common for your truck) you should be all set. Good luck.
Rob
"Stuck with a m*par, Settle for a ch*vy, Happy with a Ford!!!!"
Old 08-26-2000, 07:41 PM
heavymetal's Avatar
heavymetal
heavymetal is offline
429scj mounts
Tbird is right. I just put a 429CJ in a 77 F100 using 460 mounts found at PAW in Ca. They kept the engine level and still could use the oil pan and pickup that was on the engine, changing oil is tight when it comes to the drain plug , but manageable. if you need the number to PAW Email me Rodnwc@prodigy.net
HeavyMetal (Rod)
Old 08-29-2000, 09:34 PM
secrist_2000's Avatar
secrist_2000
secrist_2000 is offline
429scj mounts
429SCJ
03-02-2014 12:08 PM
Joinedfree13
01-21-2012 08:12 PM
turtle13b
03-17-2010 10:01 PM
pursang
22
10-06-2005 03:19 PM
tess100
02-06-2004 04:26 PM
Quick Reply: 429scj mounts
