74 460 4v hp/tq? - Ford Truck Enthusiasts Forums
74 460 4v hp/tq?
Old 08-27-2000, 01:10 PM
secrist_2000 secrist_2000 is offline
secrist_2000 is starting off with a positive reputation.
74 460 4v hp/tq?
We have a 1974 ford f250 camper special with a 460 . We were wondering how much power it has. Does anyone know?
Old 08-29-2000, 04:54 PM
heavymetal heavymetal is offline
heavymetal is starting off with a positive reputation.
74 460 4v hp/tq?
It is approx. 364 HP @ 4600RPM
It varied year to year as the changed Combustion Chamber size.
HeavyMetal (Rod)
Old 08-29-2000, 10:34 PM
74 460 4v hp/tq?
Is that gross hp? It can't be that much.
Old 08-31-2000, 02:09 AM
foxxxhunter foxxxhunter is offline
foxxxhunter is starting off with a positive reputation.
74 460 4v hp/tq?
You are correct thinking it is too high, Only the early high compression 460's had 365 HP in 1972 they dropped to 275 with the torque down to 375 from 500 ft lbs in 1969. There might be a change in 72 as to how they were rated but there is NO WAY the 8.5:1 comp engines make as much HP as the 10.5:1 comp engines 0f 1968 to 1970
Just find a book that has specs in it and you can see for yourself.
Foxxx
Old 09-03-2000, 12:41 AM
Torky Torky is offline
Torky is starting off with a positive reputation.
74 460 4v hp/tq?
For sale 460 conversion ihf-350 1967 - 1972 F-100 & Larger F-Series Trucks 0 08-09-2015 12:36 PM
Swapping boat engine Sleekcraft76 Fuel Injection, Carburetion & Fuel System 1 06-04-2015 11:15 PM
Ford MPI for 460 - aftermarket computer suggestions Rediranch_too Fuel Injection, Carburetion & Fuel System 5 06-24-2004 02:48 AM
Compression Pressure i_alone Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 15 07-15-2003 12:44 AM
302 to 460 swap chilly460 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 07-12-2000 12:32 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
