need 460 parts, or parts source - Ford Truck Enthusiasts Forums
Old 09-20-2000, 10:34 PM
progreg progreg is offline
progreg is starting off with a positive reputation.
Taking engine (460) from auto and putting it in f250 4wd.
I need oil pan, sump, exhaust manifolds, brackets that bolt on to frame of truck and motor drops into.
How much would headers run?
Need info on aftermarket parts source for 460 engines and acc.
Old 09-21-2000, 03:34 PM
heavymetal heavymetal is offline
heavymetal is starting off with a positive reputation.
I just finished a 429 rebuild and used PAW in Ca. for the motor parts and motor mounts and headers. I used Hooker Headers $329 about. Email me if you want the Phone number. They charge for the catalog but well worth the $8 You can dream all day with the catalog.
HeavyMetal (Rod)
Rod@norhwestern.ws
1977 F100 429CJ over one ton of fun.
Old 09-22-2000, 07:57 AM
Bogn Bogn is offline
Bogn is starting off with a positive reputation.
Jegs has hooker competition headers for 80'-up F-150, F-250's with 460's for around 200$ and Headman also makes headers for both the 80 and up and 79 and down for around 110$ from summitracing.
Old 09-22-2000, 08:22 AM
I bought a $175 set of headers, they would not fit. After the rebuild I did with conversion motor mounts the headers would not fit. They are now eye candy behind the garage. The hookers drop down below the front crossmember on the tranny. They worked too well. just my 2 cents.
HeavyMetal (Rod)
1977F100 429 CJ Bored Milled and built
Old 09-26-2000, 01:11 AM
TBirdGuy TBirdGuy is offline
TBirdGuy is starting off with a positive reputation.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
