Thanks for all the feedback - it was fun, but very tiring. I have an excel spreadsheet with all the information in it that I am willing to e-mail anyone that is interested - just send me a PM.
Ozx3+1 - where did you hear about the Beck Arnley ball joints and do you have personal experience w/ them? I am very interested, but I am taking a bit of a break on internet searches right now ...............
I run Beck Arnley on my truck. I learned of the downfall of MOOG as I shopped for ball joint service on my truck. I then put two & two together and realized why the MOOG's never lasted on my old F150. The "Problem Solver" series of MOOG parts manufacturing methodology (low cost "almost" MOOG parts) trickled into the mainstream manufacturing Moog processes (cost savings efforts), thus screwing the pooch...
Thanks boss.... I am new enough to really appreciate the work that went into this and the value of this as a single source "must read". Jus lookin out for the new guy.
In addition to what's already been posted in regards to head gaskets, I also recommend regular change of fuel filters, depending on use of vehicle(no more than 15K). Also, use only Motorcraft filters, as aftermarket filters can lead to driveability issues and or costly repairs. Ensure HFCM is obtaining proper pressure, measured at secondary filter housing. Also, inspection of check valves inside banjo bolts on heads can be helpful. Finally, the cetane booster available at any Diesel Ford Dealer, will optimize the quality of your fuel, lengthening life of engine parts.
FordWrench, you work at a dealer? Sounds like it. I have mine service done at my dealer. As good a deal as anyone around and I trust them. People from 50 miles away or more bring their diesels in for work, especially ambulance services. I also use the cetane boosters/treatment I get there.
__________________
Larry
PSD Addict #13
2003 F350 CC DRW 4X4 (6X6)
6.0L with auto tranny / Superchips FlashPaq
RhinoLiner / Grill Guard
Recon Smoke Cab Lights / Recon LED Dome Lights
60" White Lightening Tailgate Light Bar
2002 Excursion Limited 4X4 V10 Bone Stock
6L PWR - THANKS!! The oil temp alarm point was meant to be recommended at 240. The engine begins to defuel at 254. I did a lot of cutting and pasting to get this to allow me to post, so no telling how that got there. All comments are extremely welcome. Above all things I want this post to be as accurate as possible.
I wonder if the administrator can give me access to correct this one in the original post ????
__________________ Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; Valvoline Premium Blue Extreme 5W40; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; DashDaq on deck; Line-X, CPOhighway Products tool box, tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox
I have a 2004 and my oil temp gauge has went up to 260 on hard climbs pulling my fifth-wheel. When I took it to dealer he said that was ok for short periods. He also told me the truck would start to defuel at 280. He said this would show up on my computer and to bring it in if that happened as my oil cooler is under warrenty???
The engine begins to defuel at 253 degrees (PC-ED manual - see below). You seem to have a problem (perhaps plugged oil cooler) or you have a bad aftermarket gauge. Ask the dealer to show you where it says that defuels at 280. It may just be you need to find another dealership.
Fueling Corrections
The PCM adjusts the injector output based on the oil temperature information received from the
engine oil temperature (EOT) sensor and turbo boost information received from the manifold
absolute pressure (MAP) sensor and the barometric pressure (BARO) sensor. These corrections
are necessary to meet emissions requirements and to optimize power. The engine coolant
temperature (ECT) and the EOT sensors are used as the primary input to the PCM to enable
adaptive cooling. This provides a means of providing adequate cooling in severe engine
temperature conditions. When the ECT is greater than 105°C (221°F) or the EOT is greater than
123°C (253°F), the fueling rate of the engine is modified to provide cooling protection and prevent
engine damage due to overheating. Outputs of these sensors can be monitored using a diagnostic
tool reading PIDs.
Also - Your problem really should be posted in a new thread. I would like for this one to be on the topic of "preventing problems"
thanks!
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
