Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 02-11-2008, 02:29 AM
FireControlman FireControlman is offline
FireControlman is starting off with a positive reputation.
tag for later
  #17 (permalink)
Old 02-11-2008, 07:24 AM
brickie's Avatar
brickie brickie is offline
brickie has a very good reputation on FTE. brickie has a very good reputation on FTE. brickie has a very good reputation on FTE. brickie has a very good reputation on FTE.
This needs to be a sticky!
__________________
Tony 03/04 6.0L 350 Crew ,DRW,ZF-6, XLT fx4, EconoMax injectors, Autometer Fuel, Boost & EGT. Fass 95/90, Sct X-III with some sweet Spartan tunes, ARP studs, RR fuel system, Southbend FB8, Fluiddamper, Ali Arc hunting bumper,Light Force, Ride-Rite helpers,Ford APCM and some other stuff.
03 6.0L Ex LTD mostly stock motor and a bunch of bolt ons on the truck.
  #18 (permalink)
Old 02-11-2008, 09:12 AM
jmaskew's Avatar
jmaskew jmaskew is offline
jmaskew is gaining momentum as a positive member of FTE. jmaskew is gaining momentum as a positive member of FTE.
EGR System
Install a coolant bypass filter to help prevent the oil cooler from becoming plugged which will cause the egr cooler to fail.
I know a lot of people like to delete the egr cooler; are there fines associated with deleting it if you're caught? Will it have an effect on passing emissions? Is the oil cooler really that necessary? Is there a way to set the oil cooler up as a bypass just like the coolant bypass filter set up (if that sounds silly it's because I'm not a mechanic but I had to ask).
__________________
^Camping at ZION NP, Utah^
Jonathan
2004 F250 PSD SB King Ranch 4x4:Build Date: 01/23/2004
Dieselsite Coolant Bypass Filter, High Idle Mod
Fumoto Oil Drain Valve, Harpoon Mod, Zoodad
Isspro 40 PSI Boost, Water Temp, Oil Temp and Trans Temp
  #19 (permalink)
Old 02-11-2008, 09:19 AM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE.
Quote:
Well here if your above a certain weight your exempt from emissions, but it depends on how you have to be tested when you go thru emissions. If it's a simple OBD-II testing then more then likely you'll be fine or it's easy to have the computer flashed in such a way that you'll pass it if you get it done within a mileage limit or maybe a custom tune for emissions from Matt might help it. You'll probably have to have a custom tune if you have idle emissions testing(regular and high idle). As to the fines, I'm sure there are fines, as to what they are you'll probably have to go to your state's website to find that info out or do a search for it.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
Suncoast Heavy Duty Torqshift Rebuild
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #20 (permalink)
Old 02-11-2008, 09:32 AM
zss42002 zss42002 is offline
zss42002 is starting off with a positive reputation.
great post needs to goin the tech folder
__________________
2007 6.0 OUTLAW Lariat
Mods: 08 OEM Leather Seat Covers, BD Elec. Boost Builder, XCAL 3 Innovative Tuned, 4" MBRP Exhaust, Studs (ARP), Liberator EGR-Delete, Fluidampr, Dashawk w/ EGT probe, Fumoto valve, HFCM drain plug, coolant filter
  #21 (permalink)
Old 02-11-2008, 09:47 AM
rchouser rchouser is offline
rchouser is starting off with a positive reputation.
This is REALLY VALUABLE. I have been with my 06 for 8 months now and FTE has been invaluable. PLEASE make this Sticky. It should be a must read for new guys. I would have LOVED it. Thanks Mark. rc
  #22 (permalink)
Old 02-11-2008, 10:09 AM
thedaddycat thedaddycat is offline
thedaddycat is gaining momentum as a positive member of FTE.
Great post, you went to a lot of effort for everyone else on this one. I have given you rep points for it, you surely deserve them!
__________________
'03 F-350 XLT 6.0 PSD SRW SC SB FX4
Dieselsite coolant & tranny filters, Bright Box,
22" wipers, M-H FD RD Tranny covers, Fluidamper, leveling kit
TAG, Power Elbow, Blisteins, gages, MBRP 4" Turbo-back
XCal2 by SDT, HFCM drain, Centrimatic balancers
ESP luber, Oilguard bypass filter
  #23 (permalink)
Old 02-11-2008, 10:49 AM
jmaskew's Avatar
Quote:
Unfortunatly here in Las Vegas they increased the minimum weight on diesels so we have to go through emissions. When I do the emissions this year I will ask the tech exactly what kind of test they run to see if it is a simple test or idle emsission test.
__________________
Jonathan
  #24 (permalink)
Old 02-11-2008, 11:51 AM
tex25025's Avatar
They have upped the limit here several times, luckily I'm still exempt, but it is just the simple OBD-II testing and that really is a joke until the computers are more sophisticated to handle trickery tuning. Back home in Plano, they were a little better about the emissions and by better I mean what is needed if you are truly concerned about testing for emissions violations rather then just trying to get people's money. The only bad thing is that it took about an 30-40 min to do the testing not to mention the wait you had to go thru to get to it.
__________________
Fluidampner
Headstuds
FASS 150/180
  #25 (permalink)
Old 02-11-2008, 03:32 PM
IB Adrian's Avatar
IB Adrian IB Adrian is offline
Administrator
2005 Ford Falcon
My Garage
IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation
Added to the Tech folder
__________________
Adrian
FTE Guidelines
Quote:
Originally Posted by WhëëlMå1
... he is a mouthy broad.
  #26 (permalink)
Old 02-11-2008, 03:52 PM
ozx3+1's Avatar
ozx3+1 ozx3+1 is offline
And the price is paid
2004 Ford F-Super Duty
ozx3+1 is gaining momentum as a positive member of FTE. ozx3+1 is gaining momentum as a positive member of FTE.
Beck Arnley (WAY BETTER STUFF!) grease-able ball joints when OEM wears at between 50k and 100k. MOOG use to be the stuff, but they have a new quality initiative, and it's got more to do with the cost/quality directive more so that just QUALITY regardless of cost.
__________________
Brian
  #27 (permalink)
Old 02-11-2008, 03:58 PM
walrus's Avatar
walrus walrus is offline
walrus is gaining momentum as a positive member of FTE. walrus is gaining momentum as a positive member of FTE.
Rep points to bismic!
__________________
Mark
2006 F250 SD CC FX4 Lariat 6.0 PSD
2001 F150 CC 5.4L
"Proudly clinging to my Guns and Religion."
  #28 (permalink)
Old 02-11-2008, 05:02 PM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident Smarta$$
2004 Ford F-250
D8chumley is gaining momentum as a positive member of FTE. D8chumley is gaining momentum as a positive member of FTE.
Ditto, great post! Tried to give rep points but I have to spread some more around first before I give you and Maximum some more!
__________________
'04 F250 KingRanch CC FX4 6.0 swb "BIG D"
Tim
GO FLYERS! GO PHILLIES!
Originally Posted by hubler13f
When congress refuses to provide soldiers with the equipment to complete the mission. S.T.E.A.L. Sudden Transfer Of Equipment to an Alternate Location
  #29 (permalink)
Old 02-11-2008, 08:21 PM
bismic's Avatar
bismic bismic is offline
bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold
Thanks for all the feedback - it was fun, but very tiring. I have an excel spreadsheet with all the information in it that I am willing to e-mail anyone that is interested - just send me a PM.
Ozx3+1 - where did you hear about the Beck Arnley ball joints and do you have personal experience w/ them? I am very interested, but I am taking a bit of a break on internet searches right now ...............
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; Valvoline Premium Blue Extreme 5W40; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; DashDaq on deck; Line-X, CPOhighway Products tool box, tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox
  #30 (permalink)
Old 02-11-2008, 08:44 PM
Green_Monster Green_Monster is offline
Green_Monster is starting off with a positive reputation.
bismic great job what a boat load of info, even for people that have been following along excellent.
Tags
1879930c91 , 2004 , 60 , 60l , common , cooler , crankcase , diesel , egr , f350 , failure , ford , head , httpwwwforddoctorsdtscomarticlesarticle0515php , injector , price , problems , troubleshooting , tube , wwwforddoctorsdtscomarticlesarticle0612php
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
