Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-10-2008, 10:25 PM
DynaMow is starting off with a positive reputation.
HELP, please hurry I am losing money fast
Thanks in advance!!
96 F350. 5.4L But really probably general question.
Got in truck tonight (very cold out) and when I was yanking somebody out of the ditch in front of the house (good old snow) and my red battery light came on, which I assume means no charging?
So I get him out (of course its a Ford) and go to back in driveway and attempt to put up snow plow (drainage) lights go real dim, truck quits.
Now plenty of lights, but nothing at key start. No drag, no click, nothing. Now I am dead in the middle of the snow covered street. A guy with a Chevy pulls me (still not sure how it was able to do it) into driveway.
Now 30 minutes later I get drag on startup, but not enough to start. I am going to try it again in 30 minutes.
Alternator?
Reason I am losing money.
Its finally snowing, and my plow machine is now down.
Please give me opinion. I know there are experts here. thank you.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-10-2008, 10:31 PM
DPorter is starting off with a positive reputation.
check all your connections. Battery cables, alternator, starter, anything to do with charging and starting, also your plow wiring. You most likely had something come loose or unplugged.
Could a battery have shifted when you were pulling and grounded a post or cable?
__________________
2004 F350, 6.0, auto 4x4, CC LB Lariet, Arizona Beige with Black
High Idle Mod, 285/75/16's
  #3 (permalink)
Old 02-10-2008, 10:38 PM
Quote:
That is a great suggestion, I will do that once i get her started and moved to garage.
That should be all good, but I will check that.
thank you DP, I will let you know, what if all is tight? Where would you go then?
What is the exact definition of that red battery light?
Thank you
  #4 (permalink)
Old 02-10-2008, 10:45 PM
Why would there be nothing at original shutoff, and the after setting 30 minutes it has some juice?
  #5 (permalink)
Old 02-10-2008, 10:55 PM
A drawn down battery will recover a bit after cooling off and sitting awhile. but not to full recharge.
__________________
  #6 (permalink)
Old 02-11-2008, 12:38 AM
BroncoChris88's Avatar
BroncoChris88 has a great reputation on FTE.BroncoChris88 has a great reputation on FTE.BroncoChris88 has a great reputation on FTE.BroncoChris88 has a great reputation on FTE.BroncoChris88 has a great reputation on FTE.
Prob alternator and a fuse in the dash
__________________
Chris
DE Chp Mem
Mid-Atlantic Chp Mem
Hononrary Mem of NE Chp
To Join The Delaware Chp Click here
MIDATLANTIC REGIONAL MEET AUGUST 7--9, 2009 For Info Click Here
Quote:
Originally Posted by glruff View Post
I saw it in you post and not the one Brian did, omg gettin oldie
  #7 (permalink)
Old 02-11-2008, 12:39 AM
when alternator goes there is a fuse that blows feeding to the Instrament cluster
__________________
Chris
DE Chp Mem
  #8 (permalink)
Old 02-13-2008, 07:42 PM
Well did you get it fixed yet?
__________________
  #9 (permalink)
Old 02-15-2008, 11:05 PM
99f350sd is starting off with a positive reputation.
There wasn't a 5.4 in a 96 was there?
__________________
99 F350 5.4 Lockers,Warn winch,Hubs..Diablo Predator
MDII Plow, 200 amp alt timbrens,Revo's
85f150, THREE 96 aero*awd 4.0 ext. 05 mountaineer V8 Awd
Lever's are cool enough for me too...LOL
  #10 (permalink)
Old 02-16-2008, 01:32 AM
Vladimir Hyde's Avatar
Vladimir Hyde is starting off with a positive reputation.
i had my battery light go on too, took the alternator out, had it tested and it was a fail. but the battery still wouldnt hold charge, then i got a new battery(which i could use anyway cause the old one was from 2002) and it still runs electric solely off the battery while the truck is running with no charge up and that battery light is still on. i didnt know a fuse blows when the alt burns up, could that be why my charging system is still failed after $150? please help!!
__________________
Goliath(Project):
http://www.cardomain.com/ride/2952120
1988 F150 Custom
4 Speed 4X4
4.9L 300cid I6 EFI
Moose(parts truck[parts available for sale]):
1989 F150 Custom
5 Speed Manual OD 4X4
5.0L 302cid V8 EFI
Beast(Sold ):
1989 F150 Custom
4 Speed 4X2
4.9L 300cid I6 EFI
  #11 (permalink)
Old 02-16-2008, 10:39 AM
If your alt isn't putting out 14-14.5 volts its not working. It may be the wires going to it. Check the fuseable links and 12volts to the alt with key on.
Dick
__________________
  #12 (permalink)
Old 02-16-2008, 11:12 AM
false alarm, the old alt was bad which is why i was so confused when the new one wasnt working either, turns out i didnt re-install one of the harnesses tight enough. stupid mistake. ALWAYS CHECK WIRE CONNECTIVITY EVERYONE!!!
__________________
Goliath(Project):
1988 F150 Custom
4 Speed 4X4
4.9L 300cid I6 EFI
1989 F150 Custom
5.0L 302cid V8 EFI
Beast(Sold ):
1989 F150 Custom
4 Speed 4X2
4.9L 300cid I6 EFI
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
