Tell me what you think.... - Ford Truck Enthusiasts Forums
Old 09-17-2000, 02:58 AM
frankus frankus is offline
frankus is starting off with a positive reputation.
Well got my truck back together, after it snacked on the air cleaner retaining stud (chewed up by #4 cylinder). Did a valve job, put it back together, and started it. Well it started with know problem, but now it has a knock. Now I ask you, is it possible I flattened a rod bearing, or is it more likely I bent a push rod? I was in such a hurry to get it back together, and get it back over the Grapevine, I never checked to see if all the rods were strait. I would think that a 460's bottom end is alot stronger then a non-hardened 2 inch stud.
Tell me what you think. Anyone? Anyone?
Old 09-20-2000, 09:38 PM
progreg progreg is offline
progreg is starting off with a positive reputation.
Take the spark plug out of that cylinder and see if the knock stops or changes. Good chance you did some bearing/crank damage. depends on how long the engine ran with the bolt in there and how fast you were going.
Old 09-21-2000, 12:03 AM
I'll try it...
Old 09-26-2000, 10:57 AM
Thudpucker's Avatar
Thudpucker Thudpucker is offline
Thudpucker is gaining momentum as a positive member of FTE.
There are also Stethascopes that can just about pin point that Knock. I'm betting against a lower end problem. More likely a collapsed lifter. Do you get a Miss with the knock, and maybe even some backfiring?
Bent Pushrods usually dont make any noise at all. Sometimes, if they are bent enough you'll hear a high pitched snapping sound.
Wrist Pins snap, Broken rings Click, Rod's thump, Mains Rap, Cracked Piston skirts clack, and all of those noises will change when you short the Spark plug wire.
Old 09-27-2000, 11:37 PM
It still runs smooth and feels like it has just as much power, but there is still a steady knock. From inside the cab it sounds like it's coming from down low, like from the right front tire. Obviously it is not the tire. I like the idea of the stethascope I'll try that. Thanks
Old 10-04-2000, 07:10 AM
DeenHylton DeenHylton is offline
DeenHylton is starting off with a positive reputation.
EFI Manifold questions? FuzzFace2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 32 02-04-2017 08:07 PM
How do I diagnose and replace a bent push rod? doug42190 6.0L Power Stroke Diesel 12 06-10-2016 10:25 AM
Finally gonna start assembling the new engine... Pkupman82 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 04-10-2016 12:27 PM
Turbo Pedestal Question ?? Cell's 1999 - 2003 7.3L Power Stroke Diesel 2 08-08-2014 08:45 AM
Intake valves sticking webslinger67 1967 - 1972 F-100 & Larger F-Series Trucks 3 10-14-2013 03:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
