Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Exhaust Systems
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-10-2008, 10:06 PM
bengen is starting off with a positive reputation.
92 f-150 4x4 extended cab, long bed, 351, exhuast?
Alright, I have the above truck, 178k miles, with the rear cat gone and single 2.5" pipe w/turbo muffler (forget the brand, but was recommended here) exiting towards ground before axle.
Anyway playing around, it used to exit out p/side before rear wheel, I liked the way it sounds w/just straight pipe. Will running just tube cause any engine problems? I would like to take the front cat out but it is that molded y tube collector from the exhaust manifolds. With the high mileage I wonder if it is restricting flow. It is a pretty good muffler itself. Any suggestions how to gut it? Building a replacement piece would be difficult and most muffler shops wont remove the cats. Would straight pipe, no cats, and turbo muffler be enough back pressure if needed? How much is needed? Of course will keep the O2 sensor.
Thanks for help, suggestion, opinions.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-10-2008, 11:56 PM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
Ok, firstly, running without cats is illegal and can be dangerous from a carbon monoxide standpoint. So I will not recommend it, but it is your truck and you can do what you want with it.
If you are going to eliminate the cat, don't mess with gutting it. Gutting it will turn it into a big expansion chamber than will make your exhaust sound hollow and could hamper performance. Approach it from a standpoint of minimum turbulence. Minimize bends and sudden pipe size changes. If it were mine, I would mess with the cat unless there was something wrong with it. And at that point, I would replace it with a good high flow cat.
I like your idea of 2.5" pipe, if designed correctly that will produce a lot of torque.
I wouldn't worry about backpressure since you don't need pressure to run correctly, just velocity. You want the exhaust gases to move quickly through the system. Smaller pipes create more velocity, though you have to balance it against friction. The sides of the pipe create friction that will slow down the exhaust and create backpressure that in turn reduces performance as RPMs increase. As a general rule of thumb, you want to run the smallest pipe that meets the airflow requirements of the engine. I think 2.5" is a good size, though 3" would be excellent too.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
  #3 (permalink)
Old 02-11-2008, 12:50 AM
BroncoChris88's Avatar
BroncoChris88 has a great reputation on FTE.BroncoChris88 has a great reputation on FTE.BroncoChris88 has a great reputation on FTE.BroncoChris88 has a great reputation on FTE.BroncoChris88 has a great reputation on FTE.
I went to a exhaust shop and had them make me a custom y-pipe with a high flow cat.
__________________
Chris
DE Chp Mem
Mid-Atlantic Chp Mem
Hononrary Mem of NE Chp
To Join The Delaware Chp Click here
MIDATLANTIC REGIONAL MEET AUGUST 7--9, 2009 For Info Click Here
Quote:
Originally Posted by glruff View Post
I saw it in you post and not the one Brian did, omg gettin oldie
  #4 (permalink)
Old 02-11-2008, 09:34 AM
Sponsor
Post a sound clip, we would love to hear it.
__________________
My Rides
175,000 miles
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
  #5 (permalink)
Old 02-11-2008, 11:33 AM
once i figure out how i will
__________________
Chris
DE Chp Mem
  #6 (permalink)
Old 02-11-2008, 10:35 PM
Thanks for the replies.
I'm not opposed to running a cat, I just figured with 178k it can't be as free flowing as it was years ago. This front one is part of the y-pipe up to the exhaust headers and I it can't be cheap. Maybe a custom y like above and a high flow. How can you tell/test for the condition of an old cat like mine? Can't even see in it with a flash light when I cut the original pipe off next to it. Has a bend there.
Torque is what I would like. So 2.5" it will be. Any advantage to headers over stock manifolds without any other intake mods?
  #7 (permalink)
Old 02-12-2008, 01:17 AM
Sponsor
A cat does not become restricted or plug up with time or mileage. It will however become clogged up and eventually fail with lack of maintenance. I have vehicle with higher mileage and stock cats and they still run great. But once an O2 sensor goes out or some other condition that starts dumping fuel or oil, its all over. The large torpedos on the ford heavy duties do tend to fracture and clog themselves. It is a design flaw. But so long as that doesn't happen, the unit will perform just fine. The easiest way to post a sound clip is to post it as a video on youtube.
__________________
My Rides
175,000 miles
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
