Quote:
Originally Posted by BlueOval460
First let me say that i appreciate your opinion, but from what i have read just glancing over some sites and from some of the classes i actually paid attention to in school, there isnt much difference in the btu's of energy in regular and premium (actually Regular gasoline has more btu's than aviation fuel which is 100 octane ,(125K:120K), you make the power from the compression, timing, and or boost that makes you use the higher octane fuel. So therefore by using water injection you can use lower octane fuel and make more power. not trying to be a smart *** and definately not saying that i know alot about water injection (thats why i originally posted) but those are the reasons i have considered for using water injection but like you say if the bottle runs out then i'd be screwed but i would probably use a rather large tank say a couple of gallons and i would check it regularly and have a gauge to monitor the water pressure, weight isnt an issue as its going to be in a 4x4 "almost" daily driven truck, not tryin to make any enemies just stating my reasoning
No enemies here, this forum is for both parties to learn and have an adult conversation. The small amount of BTU gain you are going to see is neither worth the risk of the water/methonal injection. It is not just the running out either, you have a pump to worry about, and you have a very very fine nozzle where small debris can easily get stuck and clog. Also, the higher octane, which I am sure you know, is more of concern in its regards to anti-knock. It has built in what you are trying to accomplish with lower octane combined with and water/methanol injection system.
Good luck with either route and keep us posted.
