check E-bay there`s alot of prestige replacement remotes on there. as far as the switch, if it has alarm too it`s probably A overide if you lose your remote while the system is armed youd put the key in the on position & press the button to manually overide the alarm you also use them to do programming sometimes.
__________________
2004 f-250, 6.0, crew cab, shortbed 4x4.pull-rite 5th wheel hitch,air lift air bags,autometer gauges,code remote start & alarm,pioneer stereo,alpine amp, jl audio 10` sub, magnaflow muffler & my cat ran away.
