02-10-2008, 09:54 PM
Your in luck, I've been there and done that. It's fairly easy to do with the right tools. My buddy at the exhaust shop torched the metal off that holds the "horse hair" in place in the top half of the housing. It was smokey and very smelly. Let it cool off and take a good sized pair of pliers or channel locks and grab the remaining metal band pull it from under the lip of the top. Instead of a torch a grinder with a cut off wheel would of worked also. Then we did some measuring, actually did a lot of measuring. And we had a K&N application catalog at our disposal, find the section that breaks them down by dimension and order the part number given. I'll look at the number I came up with for my '55 F100, and post another reply. Good Luck!
