Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 02-10-2008, 07:58 PM
Mr.ford Mr.ford is offline
Garage is empty, add now
Mr.ford is starting off with a positive reputation.
Jet Fuel
Hey all ,
Has anyone ever used jet fuel? if so what did you do to the fuel ? i heard something like you can add some oil and its good to go ..
  #2 (permalink)
Old 02-10-2008, 08:59 PM
George D.'s Avatar
George D. George D. is offline
1994 Ford F-350
George D. is starting off with a positive reputation.
Most air force support vehicles are ru off jet fule I think tey just dump it in but I'd add some oil if it were going in my truck.
__________________
94 F350 Crew Cab Long bed 4X4 6.9L with turbo AKA The Land Yacht. E4OD, 4.10 posi. Getting further from stock with 35 inch BFG alterains on 16 inch micky's, straight pipe, Triple A-piller pod with pyro, boost, modifyed oil presure gauge,Vote for my truck here
http://www.ford-trucks.com/forums/97...round-8-a.html
Semper-Fidelis
  #3 (permalink)
Old 02-10-2008, 09:01 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Jet fuel is basically Kerosene, and has 0 lubricants in it. If your going to use it you'll have to add some form of oil.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #4 (permalink)
Old 02-10-2008, 09:58 PM
monckywrench monckywrench is offline
monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.monckywrench has a great reputation on FTE.
JP-8 is an authorized substitute for diesel in all USAF engines that burn diesel. It does have various additives to prevent bacterial growth, etc. It's been in use for many years.
I'd run it if I had a diesel, with some two-stroke oil for extra lubricity.
  #5 (permalink)
Old 02-11-2008, 07:31 AM
LilDuke's Avatar
LilDuke LilDuke is offline
LilDuke is starting off with a positive reputation.
jp-1 was almost totaly kero. jp-2~jp4 was kero with naptha... I think jp-4 was half kero, half mogas. jp-8 is basically fuel oil with a bunch of additives to raise it's flash point, and prevent coke deposits. As it's used as a lube, coolant, hydraulic, and fuel. It was designed to replace having to cart around a bunch of different fuels. jp-2(fuel#2) jp-4(jet), avgas, mogas. etc.
__________________
Dave
Hiding in my own little corner of the world!
  #6 (permalink)
Old 02-11-2008, 12:30 PM
You an Engine troop? Only those folks would tend to know the other "on engine" uses of Jet fuel.
JP-8 use took off after the Pope "Green Ramp" crash. It was decided that losing a few aircraft to inabliity to restart in the air was a better tradeoff than the high flammability of JP-4.
  #7 (permalink)
Old 02-11-2008, 04:26 PM
Herkmafia Herkmafia is offline
Herkmafia is starting off with a positive reputation.
used to work at an FBO that used Jet A in their john deer to cut the grass on the field
Dont know if I'd want to use it in my 6.0 though.
On a side note, you'd be suprised what you can run a turbine engine on (for a little while)
Also, Jet A is running about $4.65 to over $5.00 for aviation use.
  #8 (permalink)
Old 02-11-2008, 05:42 PM
"On a side note, you'd be suprised what you can run a turbine engine on (for a little while) "
Herk engines trim to temperature, and our AFETS rep told us they'd burn quite a variety of petroleum fuels. I'm impressed with any aircraft where you can smash the tail with an F-16 and still land!
  #9 (permalink)
Old 02-11-2008, 07:03 PM
littleme13's Avatar
littleme13 littleme13 is offline
littleme13 has a good reputation on FTE.littleme13 has a good reputation on FTE.
jp-8 is safe to run in your diesels. most guys i new would only fill there tanks half way then come into work and barrow our fuel sample waste containers and fill the rest. one guy did use a 2 stroke oil just cuz he felt safer but i know a guy that rana cummins for 6 months off straight jp-8 and had no problems.
  #10 (permalink)
Old 02-11-2008, 08:21 PM
LilDuke's Avatar
77F
jp-8 has all the lube required for diesel engines. Nothing else is needed for proper performance/longetivity.
As far as fuel reqirement for a jet engine. As long as it'll burn, but not too fast, it'll power a jet engine. I've seen em run on propane.
They work very simmilar to a diesel engine as they compress air, squirt in fuel, and ignite.
__________________
Dave
  #11 (permalink)
Old 02-12-2008, 06:19 PM
hmm .. well not sure what kinda jet fuel i have .. just that i have about 400 liters worth. Ill have to find out let everyone know
  #12 (permalink)
Old 02-12-2008, 06:43 PM
George D.'s Avatar
1994 Ford F-350
I'll ask the stupid question. Where did you get jet fule? were the gaurds at the airport not watching
__________________
Semper-Fidelis
  #13 (permalink)
Old 02-12-2008, 09:23 PM
littleme13's Avatar
i used to be in the navy and worked on jets and turbo prop planes. its amazing what you can get your hands on when you knwo the right people.
  #14 (permalink)
Old 02-12-2008, 10:19 PM
zhilton's Avatar
zhilton zhilton is offline
2004 Ford F-250
My Garage
zhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to all
This whole thread reminds me of everything I've ever heard about a "Duce & a half". They'll burn anything you put in the tank. I don't know how much of that is true...but it's starting to sound like there is some truth to that statement.
__________________
FTE Arkansas chapter member
1972 Ranchero GT (351C CobraJet intake)
2001 Explorer XLT 2WD
2004 F250 6.0L 2WD CC "Pavement Princess"
2007 Monaco Starwood SL 31BHD
2012 Focus SEL (Wife's ride)
  #15 (permalink)
Old 02-13-2008, 11:00 AM
1935 Ford pickup
Quote:
True. It's called a "multi-fuel" engine, and will run on just about any liquid that will burn. After working on them "overseas" in the "60's" all I can say is THEY ARE A PAIN IN THE *** to work on...................
This will describe it better: http://www.tpub.com/content/engine/1...s/14081_20.htm
__________________
Tags
73, ak, alternative, barrow, bowsers, burning, diesel, duramax, f250, ford, fordfuel, fuel, jet, jeta50, run
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
