Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-10-2008, 08:51 PM
mike200521 is starting off with a positive reputation.
Exclamation upfitter switches
I am putting a strobe kit in my truck (06 f250 5.4l) and i want to use my upfitter switches. The kit say use a switch that will deliver 15 amps. now the switches are 10amp and 30 amps. Is there a way to change the amps? Can you change the fuses on them... thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-11-2008, 04:15 AM
blue beast's Avatar
blue beast is gaining momentum as a positive member of FTE.blue beast is gaining momentum as a positive member of FTE.
Have the switch control a relay that way you don't have much amperage pulling at
the switches and you can add more lights to that circuit if the relay you use can
handle the load that is.http://www.skycraftsurplus.com/index...TS&Category=95
They got the bosch type relays all the way up to 80 amp if you needed it or that 300
amp relay solenoid if you wanted to overbuild it for who knows what!!
__________________
86 fs bronco 302 auto 33x12.50 at rusty but trusty!
04 Ranger edge 3.0 5 speed auto 4.10
Before posting fuel related problems Run a couple of bottles of dedicated gas line dryer through IT!!!!!!!
There now I don't have to say it every time!!!!
  #3 (permalink)
Old 02-11-2008, 08:56 AM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
The upfitter switches already have relays. It's ok to use a circuit larger than you need for your circuit. I would use one of the 30 amp circuits for your 15 amp load. If you are really worried about it, you could find the 30 amp fuse for the aux circuit you are using, and take it out and put a 15 amp fuse in it's place. But I think it would be unnecessary.
__________________
Dave F
1989 F250 XLT Diesel
  #4 (permalink)
Old 03-11-2008, 07:55 PM
FoMoCo136's Avatar
FoMoCo136 is starting off with a positive reputation.
I have an 06 F-150. Do they make the upfitter switches for this truck? I still have the ones out of my 07 F-350. Is there a way to use the ones from the Super Duty in the F-150.
__________________
2006 F-150 4X4 3" Leveling Kit Nitto 35", SCT Tuner, All the gauges, Heavy Right Foot
  #5 (permalink)
Old 03-11-2008, 10:42 PM
Franklin2's Avatar
I am sure you could hand wire them in place. If you want this to be plug and play, then you might have to go to the dealer and get a kit or something. They usually do not offer this option on a f150, since the upfitter switches are used for added equipment that is usually added on the f250's and up.
__________________
Dave F
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
