Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 02-10-2008, 07:05 PM
IABill's Avatar
IABill IABill is offline
Garage is empty, add now
IABill is gaining momentum as a positive member of FTE.
Question Linnseed Oil? (sp)
I have an opportunity to get some linnseed oil and was wondering if anyone has used this, is it similiar to peanut or a vegetable oil that can be used for the production of biodiesel?
Will it work or will I be making soap....What do you all think???
Thanks
Bill
__________________
Light travels faster than sound.
That's why some people appear bright until you hear them speak.
2007 F-350 Lariat CC,LB,SRW,2x4, Brite Box, High Idle sw, No Kitty & Straight Pipe, Blue spring & Sinister coolant filter & Fumoto.
  #2 (permalink)
Old 02-10-2008, 08:57 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
As long as it isn't "boiled" linseed oil it should work.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 02-11-2008, 12:10 PM
IABill's Avatar
Talking
Thanks Fab I will check, did not know to ask that question.....Bill
__________________
  #4 (permalink)
Old 02-11-2008, 08:03 PM
firemediceric's Avatar
firemediceric firemediceric is offline
firemediceric is starting off with a positive reputation.
I've never thought of linseed oil for anything other than oiling the wood on my guitar or some furniture. All of the bottles I have seen say "Boiled" on the label.
What's the difference between the boiled and the non-boiled?
__________________
1999 F-350 with Tymar type air filter, Dahl 100 fuel filter, HP oil X-over, bypass oil filter, coolant filter.
  #5 (permalink)
Old 02-21-2008, 08:27 PM
diofanbo diofanbo is offline
diofanbo is starting off with a positive reputation.
Have you tried the linseed oli sounds like a bad recipe when you heat it but i could be wrong
  #6 (permalink)
Old 02-21-2008, 09:24 PM
IABill's Avatar
Wink
Not yet been to darn cold here, today better almost 15....at least thats above zero......will let you how it works if it ever warms up!!!
__________________
  #7 (permalink)
Old 02-22-2008, 09:16 AM
jimmeste's Avatar
jimmeste jimmeste is offline
jimmeste is starting off with a positive reputation.
Linseed oil is the another name for Flax seed oil. I don't know how it will work for Bio but it should make your engine healthier. If I can find more info I will post.
__________________
2004 F250 CC Lariat 6.0 FX4
2002 Explorer Eddie Bauer 4.6L 4X4
2005 318BHS Montana Mountaineer
  #8 (permalink)
Old 02-22-2008, 09:27 AM
jimmeste's Avatar
Here is what I found in a quick search of the Biodiesel Forum. Use of Flax Seed Oil aka Linseed Oil, not recommended. It has a high IV (Iodine Value) and is classified as a drying oil. This drying characteristic is why it is used in paints and finishes. It tends to gum things up rather easily. I would suspect that these properties would be somewhat present in the processed Biodiesel. I would definitely recommend test batches.
__________________
  #9 (permalink)
Old 02-26-2008, 10:08 PM
crosbo's Avatar
crosbo crosbo is offline
crosbo is starting off with a positive reputation.
Interesting. I seem to recall a number of years ago a custom harvester that pissed off another custom harvester in Colorado or Wyoming...and one poured a small bottle of iodine in the fuel tank of one of the other's combine...something about the iodine causing the engine on the $100K piece of farm machinery to seize.
__________________
__________________
Tom
'00 CC F250 4x4 Auto 4" Magnaflow, S&B Cold Air Intake, AIH, Edge A2/Juice, HPX, Pre-pump, In-Tank, CCK, 203 Thermostat, Air Horns, XM Satellite Radio, 2" lift, 315's, Trucool 4739, '06 Grill and emblem upgrades, RealTree skins and a hot babe in the passenger seat!
Tags
linn, linnseed, oil, seed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
