specs 460 - Ford Truck Enthusiasts Forums
specs 460
Old 10-24-2000, 04:30 PM
dre dre is offline
dre is starting off with a positive reputation.
specs 460
A Newbie here on site,
I just installed a stock 87' 460ci
in my 78' F-150.
do not have any specs on engine.
1.)I need the stock compression ratio.
2.)recommended SAE oil weight.
3.)Initial Timing degrees.
Thanks for any help given
Old 10-27-2000, 12:28 AM
Junkyardslug Junkyardslug is offline
Junkyardslug is starting off with a positive reputation.
specs 460
Tags
1978, 1980, 460, 460ci, block, compression, degree, engine, ford, specs, specs460, timing, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
