Illinois Chapter Join Chapter Leader: wpnaes
96 windstar P1408 P1464
Old 02-10-2008, 06:01 PM
brian ski's Avatar
brian ski
brian ski is offline
I have a 96 windstar and have OBD2 codes P1408 and P1464. I,ve changed the injectors, changed the EGR , coil pack, cleaned intake manifold, checked all vacume lines and no leaks . I do have water in the oil , and am losing antifreeze but no leaks that I can see . It starts fine and runs fine for about 30 minutes then tries to die. Check engine flashes(is always on). Shut down and restart and runs as if nothing happened. Will continue like this until it can be shut down for at least a half hour. I thought I had it narrowed down to the PCM , that is until I saw a thread on this site with the same symtoms except no codes. they said it was a bad intake gasket. I've heard al kinds of stories about the head gaskets, 140.000 miles. any suggestions would be a big help, Thanks
Old 02-14-2008, 03:30 PM
55 f350's Avatar
55 f350
55 f350 is offline
if its got a 3.8 you probably got a blown head gasket thats where your anti freeze is going . they are / were JUNK motors . had a couple of 'em { the wife } and i'll never own anything ever again with that engine in it even if it is free . the last one kept flashing a couple of codes as it ran fine till it warmed up then went to hades , and overheated . throw it away and get something else . thats my .02 cents worth .
Old 11-11-2008, 08:30 PM
keating6614's Avatar
keating6614
keating6614 is offline
96 Winstar CEL on problems
I just replied to someone else, bas12441, on a similar problem. I do not want to repeat the process but it was my intake. Running good now. Check it out.
This thread is located at:
https://www.ford-trucks.com/forums/s...1&goto=newpost
Bartramk
Modular V8 (4.6L, 5.4L)
08-12-2014 01:18 PM
A-CoreMech
02-06-2013 02:01 PM
dlibson
03-11-2012 04:09 PM
MikeyKazoo
12-08-2011 05:59 PM
bvbunky195
Escape & Escape Hybrid
04-30-2010 07:32 PM
Quick Reply: 96 windstar P1408 P1464
