98 F-150 5.4 Voltage Regulator/Alternator - Ford Truck Enthusiasts Forums
Old 02-10-2008, 01:55 PM
hoganlo hoganlo is offline
hoganlo is starting off with a positive reputation.
Hello. I've replaced the battery in order to even get my truck back home, but the battery indicator light still comes on and flickers. I moved some wires while my wife watched the light and she said it when crazy at the time I messed with the wires where they plug into the voltage regulator on the back. They are not exposed and were'nt grounding on the body. The Volt Reg is about $60 bucks at O'rI and a new Alt is $189 at AZ.
Has anyone had experience replacing just the Volt Reg vs the whole ALt and how did it work out? I've pulled the alternator, can they test it at AZ and tell if it is the Volt Reg only vs the whole alternator? I figure they will tell me I need a new alternator even if it is just the Volt reg. Any advice would be appreciated!! Oh, also...how do you know if you need a 95 or 130 amp alternator?
Thanks,
Steve
Old 02-11-2008, 05:40 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
I would replace the whole unit if it is original. The brushes are probably pretty well worn. It should be stamped in the alt. somewhere, but I would get the 130amp.
Old 02-11-2008, 06:20 PM
sheetsd66 sheetsd66 is offline
sheetsd66 is starting off with a positive reputation.
I replaced just the brushes/ regulator about 70,000 miles ago and its still going strong. If I remember right, I got the parts at NAPA.
Old 02-11-2008, 08:24 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
brushes ride on two brass rings insdie. they take a real beating by the time you get 150k miles. I would go fo the entire alternator. If you have a small 6 cylinder, you probably got the 95 amp. The 130 is more common for bigger motor and more options or towing package. Either will fit the hole.
Old 02-12-2008, 03:10 PM
I did end up replacing the whole thing and changed the serp belt while I was at it. Everything seems to be fine an the battery indicator light has not come on since. Thanks!!
Old 03-03-2012, 03:33 PM
cardone cardone is offline
cardone is starting off with a positive reputation.
I just replaced the voltage regulator on my 97 F150. The battery light was flashing intermittently. Steve's right as usual. I have 145K on mine and the brushes were worn out. AZ said they didn't carry and alternator and Pepboys had the regulator without the brushes assembly. Got one at Ford for $81 and it's all fine now. Only wish I could have replaced just the brushes. Probably would have been MUCH less.
78 f150 new alternator, voltage reg., wiring still won't charge kyle78f150 1973 - 1979 F-100 & Larger F-Series Trucks 35 03-23-2014 01:45 PM
Rewired 67...won't turn off??? 67F250RET 1967 - 1972 F-100 & Larger F-Series Trucks 2 02-04-2013 06:23 AM
2003 7.3.....Alternator problems rwtdct 1999 - 2003 7.3L Power Stroke Diesel 14 08-07-2012 08:05 PM
voltage regulator wiring 250-highboy-76 1967 - 1972 F-100 & Larger F-Series Trucks 1 04-30-2006 05:56 AM
overvoltage from alternator? Starkbier 1978 - 1996 Big Bronco 5 08-17-2004 08:27 AM
Tags
130, 1998, 2002, 54, 95, 97, alternator, amp, f150, flickers, ford, light, loacated, regulator, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
