460 Freeze Plug - Ford Truck Enthusiasts Forums
460 Freeze Plug
Old 10-20-2000, 07:14 AM
chilly460 chilly460 is offline
chilly460 is starting off with a positive reputation.
460 Freeze Plug
Old 11-06-2000, 08:30 PM
petel petel is offline
petel is starting off with a positive reputation.
460 Freeze Plug
[font size="1" color="#FF0000"]LAST EDITED ON 06-Nov-00 AT 10:00 PM (EST)[/font][p]A freeze plug on my 1970 460 has a slow leak. It is the plug that is next to the starter. What is the best way to pull it out? Do I tap in a new one to just the same depth using a socket as the installation tool?
Also, I checked a couple of parts web sites, and they had RUBBER freeze plugs! Why? Wouldn't I want another metal one?
I thought about this a bit more, would brass plugs be the best? If one is leaking, should I really replace all the others on a 30 year old engine with 75k miles, or leave well enough alone if the others are OK?
Thanks, Pete L
Old 11-06-2000, 10:25 PM
JMR JMR is offline
JMR is starting off with a positive reputation.
460 Freeze Plug
If it were me I would not use the rubber expanding plugs, because they have a tendancy to pop out. You may have to drop the starter, knock a hole or two in it with a screw-driver and a hammer then stick a pair of channel-locks trough the hole and grab it and yank it out. I'm not sure if they make brass plugs or not. you can use a 1/2" drive extension and/or a socke to install the new one. As for rest of them, I would'nt worry about 'em til they create a problem.
Hope this helps.....john
Old 11-07-2000, 07:14 AM
cobrajet cobrajet is offline
cobrajet is starting off with a positive reputation.
460 Freeze Plug
hey Pete, i totally agree with John!! just use a regular steel freeze plug, it will last you another 75,000 miles or longer. only use them rubber ones only if it's an emergency or for a temp. fix there pretty bad. take it easy. Ray.
Old 11-07-2000, 07:21 AM
DeenHylton DeenHylton is offline
DeenHylton is starting off with a positive reputation.
460 Freeze Plug
Metal freeze plugs are always the best way to go, but if your trying to make an "in the truck repair" sometimes a rubber plug is the way to go if you don't have room to hammer in a metal one. I've had two different engines that I've installed rubber plugs and never had one blow out. Just make sure you install them dry...and when you finally pull the engine for a rebuild replace the rubber with metal. Deen
Old 11-10-2000, 12:16 AM
460 Freeze Plug
Thanks everybody! I'll have a lot more 460 questions as we head into winter, and I get more time to work on it.
Pete L.
Old 11-14-2000, 10:32 PM
jpf250 jpf250 is offline
jpf250 is starting off with a positive reputation.
460 Freeze Plug
When you install the new freeze plug it is a good idea to put a little No#1 Permatex around the edge of it. It helps to seal it from leaking and does not affect it's ability to pop out in the event of freezing.
Old 05-05-2012, 02:38 PM
7.3torquestroke 7.3torquestroke is offline
7.3torquestroke is starting off with a positive reputation.
Quote:
Hey bud hows it going?
I have a quick question i have replaced all my freeze plugs on my 78 ranger with the 302...and thoose were visible ...now i have an 89 f250 with the 7.5 460 i bielive i have a freeze plug leaking.. i cant see for sure if it is one but are there plugs behind the motor mount??? ..o yeah how many dose this block have i have been told it will vary sometimes????
Old 05-06-2012, 02:52 PM
big vann big vann is offline
big vann is gaining momentum as a positive member of FTE.
First of all this thread is 12 years old.If you have a question just start a new thread.By the way,welcome.To answer your question:There are three frost or soft plugs on the side of the 460 block.
460 engine siezed?? Pastmaster 1987 - 1996 F150 & Larger F-Series Trucks 13 06-24-2011 09:20 AM
Questions changing out 92 EFI 460 with 70's carburated 460 merc460 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 11-08-2002 10:09 AM
Lightning Motor dave460 Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 3 08-04-2001 09:14 AM
460 cam? mike460 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 03-30-2001 07:23 AM
302 to 460 swap chilly460 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 07-11-2000 11:32 PM
Tags
1989, 460, big, block, blocks, fixing, ford, freeze, install, installation, locations, plug, plugs, rubber, size
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
