Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-10-2008, 02:36 PM
van1989 is starting off with a positive reputation.
tranny ?
rebuilt my 7.3 runs great, Put in a new tourqe converter but I think I did somethig wrong.was I to put transmission fluid in it before installing or not and is there any way to put it in all put together? or pull tranny out?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-10-2008, 09:56 PM
catfish101's Avatar
catfish101 is starting off with a positive reputation.
Just put your fluid in the trains. When you run the motor the fluid will makes it way in the torque converter.
__________________
79/83/86/95 F-??? 6.9 4speed
94 350 4x4 SRW 7.3 factory turbo
1930 Model A Original
My wife has three of her own.
  #3 (permalink)
Old 02-10-2008, 10:20 PM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
I've always prefilled before installing the torque converter. You can damage the transmission before the TC is full.
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #4 (permalink)
Old 02-16-2008, 01:40 AM
ford trans tech is starting off with a positive reputation.
no you cannot damage the trans before the torque converter is full , the hydraulic system is to fill and pressurize the torque converter , it is a regulated pressure and normal hydraulic pressure is available to the valve body as long as there is adequate fluid in the sump for the pump , filling the torque converter prior to installing it is a waste of time and creates a mess to clean up , on any E4OD or 4R100 or 5R110 you can install 10 quarts in the pan before starting the engine then add an additional 4 quarts after starting the engine and then check teh level
__________________
89 F-350 CREWCAB DUALLY
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
