Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Expedition & Navigator 1997 - 2002 and 2003 - 2006 models
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-10-2008, 01:28 PM
madsonp is starting off with a positive reputation.
Ford Speed Control Recall - Check your vehicles !!!!
Due to the recent vehicle fire (yesterday) of one of our forum members (found at the following post) http://www.ford-trucks.com/forums/70...he-ground.html, I though I'd send this information out again.
For those of you who own or have recently purchased a Ford product there's an important recall that if not repaired or disabled could cause your vehicle to catch on fire. The vehicle doesn't need to be running for this to happen. The following link gives a list of affected vehicles covered under the recall.
http://www-odi.nhtsa.dot.gov/cars/problems/defect/relatedDefectsSummary.cfm?RCL_ID=05V388000&defectIdlist=EA05005&ModuleType=Vehiclestype=VEHICLE
If your not sure if this has been repaired or disabled on your vehicle then see the following photos. If this has not been done disconnect, or have the switch disconnected as soon a possible. Do not park your vehicle inside until this has been completed due to risk of fire.
Here's what to look for from my vehicles:
The first photo is my wifes 97, we haven't done the recall repair on hers yet but we've diconnected the switch (notice nothing plugged into the pink connector, the plug is hanging above the switch taped up with electrical tape to protect the contacts from corrosion) which is what you need to do if you haven't done it yet. The switch is on the end of the brake fluid reservior.
The next photo shows the recall repair harness on my 99 (notice the blue lables and tags).
For more information you can visit : http://www.recalls.gov/nhtsa.html
Please pass this information on to those you know who might be affected by this recall.
__________________
99 Expedition EB 4x4 5.4L (mine)
97 Expedition EB 4x4 5.4L (wifes)
77 E-250 4x4 Van 460ci (gas pig)
76 E-350 Motorhome 460ci (another gas pig)
42 Ford 9N Tractor (old pig)
Are you talking to me ?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-10-2008, 07:43 PM
pdqford is starting off with a positive reputation.
Just in the way of an FYI, I took my new (to me) '02 Navigator in to the Lincoln/Mercury dealer last November to have it checked to see if this recall had been done. It hadn't been done so they disconnected the Cruise Control connector and taped it up like madsonp pictured above. And then they informed me that the part to fix is on backorder and probably won't be available until 2nd quarter of '08!
__________________
Jim in Central NY
'79 2WD F-150 Lariet w/302,4spd OD, 228,965 mi. (Original Owner!)
'02 4X4 Navigator (Newbie)
  #3 (permalink)
Old 02-10-2008, 09:42 PM
monckywrench is gaining momentum as a positive member of FTE.
This problem should be a PERMANENT sticky in every forum referring to trucks that use this style switch because even with recalls we all know it will never go away.
  #4 (permalink)
Old 02-23-2008, 12:52 PM
amm888 is starting off with a positive reputation.
Any ideas on how to tell whether the recall has been performed on one's truck? My CC wire has a tightly wrapped blue label on it that has misc numbers and letters on it. It also has a white label that reads "made in Mexico."
__________________
00 Expy EB
5.4L 2x4
50K
  #5 (permalink)
Old 02-24-2008, 12:28 AM
Quote:
If it looks the same as the picture above, it's been done. Also the way you discribe it, it sounds to me like it's been done. If you're still unsure, take it to your local Ford dealer and they could tell you for sure.
__________________
  #6 (permalink)
Old 02-24-2008, 08:38 AM
i1dery is starting off with a positive reputation.
Is this for trucks with Cruise Control only???
  #7 (permalink)
Old 02-24-2008, 09:35 AM
Quote:
well, it doesn't look exactly like the picture above. my blue tag is tightly bound to the wire. i'll just pull the plug to be safe until i get around to taking her to a dealer.
__________________
00 Expy EB
5.4L 2x4
50K
  #8 (permalink)
Old 02-24-2008, 10:38 AM
tommyleea is starting off with a positive reputation.
The fix is a jumper wire with a fuse in it. Ford doesn't seem to be very proactive for a problem that burns your vehicle to the ground.
  #9 (permalink)
Old 02-24-2008, 01:11 PM
operator414 is starting off with a positive reputation.
i just went out and checked my 99 expy that I bought last month and it already has the update, looks like they installed a inline fuse? but, it does has the blue tags and looks fairly new.
  #10 (permalink)
Old 02-24-2008, 01:36 PM
"The fix is a jumper wire with a fuse in it. Ford doesn't seem to be very proactive for a problem that burns your vehicle to the ground."
'Proactive" would have been eliminating that switch and using a mechanical unit instead. Insisting on retaining such an ignorant design (the always-on power to the system is not smart either) deserves a smackdown.
  #11 (permalink)
Old 02-24-2008, 01:41 PM
sbclemens is starting off with a positive reputation.
Anyone know what the new harness consists of? Since the replacement harness is back ordered until ... is there an alternative to disconnecting the switch that we can instal until the new harness'es arrive?
__________________
98 Expy XLT 4x4 5.4L
  #12 (permalink)
Old 02-24-2008, 05:58 PM
Quote:
As far as I know
__________________
  #13 (permalink)
Old 02-24-2008, 06:01 PM
Quote:
There is no alternative that I'm aware of, the dealers just unplug it as shown until they can install the fix. Hey sbclemens, what are you doing here ? Don't you have a motor to put back together ?
__________________
  #14 (permalink)
Old 02-24-2008, 07:51 PM
Yup! No warpage on the heads. Now I'm going to gut them, clean them up and reinstall.
__________________
  #15 (permalink)
Old 02-25-2008, 09:18 AM
You got that right. I have a 94...yes I said a 94Mark VIII, with the same recall.
Who is driving that bus??
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
