Added a Leer cap, need help wiring the 3rd brake light
No biggie-
Green wire on the brake light switch. I had to run the wire along side of the big wire loom on the drivers side frame rail. I could't feed it through the gromet that was already there (under the drivers side floor), so i drilled a small hole next to it and added a new gromet. worked like a charm. It's a shame there isn't some kind of adapter to give it a factory looks, but it works just fine.
The whole project took about 2 hours...mostly because of trial and error. I imagine if I knew what i was doing from the start it would have been an hour project from start to finish. Shorter if you have a lift
Originally Posted by ddavie
I bought the cap off of a year old truck and put on my 2005. I have the ground and the dome light wired correctly, but need to know where to tie-in the wire for the 3rd brake light. any ideas on how to run this wire? Thanks!
Willie
PaxtonShelby
04-11-2010 11:03 PM
Cowboy Tom
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
07-28-2005 02:27 PM
