You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Added a Leer cap, need help wiring the 3rd brake light
I bought the cap off of a year old truck and put on my 2005. I have the ground and the dome light wired correctly, but need to know where to tie-in the wire for the 3rd brake light. any ideas on how to run this wire? Thanks!
When I got the cap on my Ranger, they ran a wire clear up into the cab to tap into a brake wire. Seems like a long way to go, but I guess the connection area stays dry that way.
Green wire on the brake light switch. I had to run the wire along side of the big wire loom on the drivers side frame rail. I could't feed it through the gromet that was already there (under the drivers side floor), so i drilled a small hole next to it and added a new gromet. worked like a charm. It's a shame there isn't some kind of adapter to give it a factory looks, but it works just fine.
The whole project took about 2 hours...mostly because of trial and error. I imagine if I knew what i was doing from the start it would have been an hour project from start to finish. Shorter if you have a lift
I’m a little late with this, so for future reference. There is a dead end wire for the 3rd brake light on a cap (topper). It’s located in a harness that’s on the frame @ the driver’s door behind a cover. See pictures. I have a 2005 Super Crew. I re-routed the wire today & put it in an enclosed shield.
Willie
__________________
****************2005 F150 Super Crew Lariat 5.4V8 & The Extras*****************
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
