Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-09-2008, 10:32 PM
PIPER-68 is starting off with a positive reputation.
Oil In 7.3 Intercooler Tubes
I had to remove the pipe coming out of the turbo on my 7.3 that goes into the intercooler because it was rubbing on the power steering pump and had a hole in it . When I took it off I found a lot of oil inside the tube . Any ideas ?
Thanks...
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-10-2008, 12:36 AM
PLC7.3 is starting off with a positive reputation.
Piper if your asking about the 2004 in your info move up a few forums.....
__________________
93 F250 SC 4x4 E4OD 355LS
  #3 (permalink)
Old 02-10-2008, 01:34 AM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
If this is for the 2004, I can move your post to the correct forum for you.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
www.ford-trucks.com/guidelines.html
FTE Moderator in the IDI diesel forum.
WV Chapter Member
  #4 (permalink)
Old 02-10-2008, 12:19 PM
Sorry , This is on my early 99 F350 dually . I also have a new F450 dually . It's a great truck so far with the exception of horrable milage . My 04 was a 6.0 liter , I got rid of that piece of crap after only 75K miles.
  #5 (permalink)
Old 02-16-2008, 12:42 AM
ford trans tech is starting off with a positive reputation.
its normal , the oil is from the turbo , they all have it on the DI 7.3
__________________
89 F-350 CREWCAB DUALLY
  #6 (permalink)
Old 02-16-2008, 08:35 AM
3/4T man is starting off with a positive reputation.
It is from the turbo and also from the crankcase breather located in the driverside valvecover alot of guys unhook this and reroute it using heater hose because they are concerned about the oil clogging the intercooler hope that this helps some.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
