Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-01-2000, 12:27 AM
riskie is starting off with a positive reputation.
460 COLD START MISS SOLVED
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-08-2000, 12:22 PM
DEEN,BB79,DANNYP THANKS FOR YOUR HELP.
Well, after checking all of the obvious I finally pulled a valve cover. What I found was that the top, last turn of the valve spring for the intake valve on No. 8 cylinder was broken. The speculation is, the reason the miss would go away after the truck was warmed and then shut off, is while its sat off , either the valve guide warmed or oil would work its way in to the point that would allow the valve to completely close . Then upon restarting the weakened valve spring would have enough tension to completely close the valve. All fixed and running.
Anyway, thanks for your suggestions.
Craig
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
