Welcome to the forum, lots of good advice here and there is lots of advice also..LOL
There are many options that are much easier and more cost effective that swapping the frame.
Rear: The brakes are easily rebuilt and the later years offer no real upgrade. The rear end is already a 9" so the third member can be easily swapped with what ever gear ratio you desire. If you want a lower stance, there are spring options to do that. and finally relocating the gas tank behind the rear end is a common and easy mod.
Front: If you want IFS, there are 4 or 5 options. I you keep the axle, there are disc brake conversions and the Toyota power steering conversion makes that easy. Lower stance can be achieved with either option.
Engine: Many engine mounts are available to install a different engine.
So IMHO, you would be money and time ahead keeping the 57 frame and deciding what you want to do to it.
Two last comments: A 72 frame will require a similar amount of rebuild for things like brakes, springs, etc.
Finally: I looked at you gallery and you have a couple good looking trucks to start with. Good Luck.
