Ford has taken a very harsh stance on the 6.4s and they don't want you to modify anything on that truck. Most places have you sign a waiver that says you realize modding it in any way voids your warranty and that would include a cat/dpf back exhaust(they say even the tip of the 6.4s exhaust is intregal to the system). I wouldn't be surprised if that would also include an aftermarket radio if your dealership is really bad about it. If you want to mod do it with the 6.0 not only for the reason above, but also most aftermarket parts are still in beta phase, it usually takes about 2 yrs before the aftermarket is really good at their parts, especially now that they are other issues that they have to contend with that they previously didn't have to.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
SCT w/Spartan tunes(including FICM tuning)
Fuel Regulated Return
FASS 150/180
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
