Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-04-2000, 08:16 PM
petel is starting off with a positive reputation.
Timing Cover, Oil Pan
'70 high-compression 460, 75k miles, seems well maintained.
Want to change out the timing chain and sprockets, to get rid of those nylon teeth. Want to change oil pan gasket too.
Check me on this - When putting it back together, put the oil pan up first, then the timing cover? Since the oil pan gasket will be new and goes all the way around. Is this the right order?
What else should I replace while in there? Figured radiator hoses, water pump, timing cover shaft seal, clean off oil pump screen, anything else? Plan on putting a new oil pump in?
When re-installing the timing cover, do I really need to hunt up a timing cover-to-seal alignment tool, to be sure that the cover is positioned correctly? Or is that a stupid question...
Thanks for your consideration!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-04-2000, 11:20 PM
bb79ranch is starting off with a positive reputation.
I hope you are doing this work with the engine on a stand and not in the vehicle, it will make life alot easier during this repair.
Definitely change those nylon sprocketed gears, make sure you use an early model timing set (I.E. Cloyes 3122) or equivalent.
If you are planning to remove oil pan to fix any oil leaks I would look at a few things inside the engine while it is opened up.
(A). See if old rear main seal needs replacement!!!
(B). Take a connecting rod bearing cap off and look at the bearing surface as well as crankshaft surface, do the same with main bearings. Make sure you put them together the same way they came apart.
(C). I would change the oil pump, it's cheap insurance.
(D). I would put the oil pan on first then the timing cover or else you will have another joint(s) in the pan gasket that will try to leak.
(E). When putting on timing cover just use the crankshaft spacer that goes through the crankshaft seal to align the cover to engine block, thread oil pan to timing cover bolts (finger tight). Install water pump and tighten these bolts as well as the timing cover to engine block bolts before you tighten the oil pan to timing cover bolts and you can be assured of a proper fit. Just remember to use a little silicone in the proper places (your gasket makers should tell you where). There are quite a few other fixes you could do it just depends on if engine is in or out of vehicle. I hope this helps in any way.
Todd
BB79RANCH
  #3 (permalink)
Old 12-13-2000, 06:20 PM
Thanks for the tips,Todd.
Sadly, I will have to work on it in the chassis.
  #4 (permalink)
Old 12-13-2000, 07:35 PM
390fe is starting off with a positive reputation.
__________________
Jason Kendrick
'70 F100 Custom 390/C6
'93 Mercury Topaz 2.3L
'99 Ford Windstar SEL
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
